- Thread starter
- #741
Here we go ...
No problem.Post pics of the interference.
80 box bolts to the out side of the frame so spacing the box out won't work.Wow that's tight. Gotta remember to allow clearance for frame flex too.
Hard to tell what's hitting. The head of the bolt? Can you space the steering box off the frame a quarter inch maybe? Otherwise, start cutting what it's fouling on.
Yes. The head of the bolt i circled fouls the spring pocket. If my calculations are right, opening up a hole in the exact spot where it hits . I haven't had time to mess with the project for the past few days but hopefully, good times will come again soon. Should not be too hard to fix...... (i hope)Wow that's tight. Gotta remember to allow clearance for frame flex too.
What i have on it is a Nissan Patrol Y 61 steering box. It is said to be way stronger than the 80 series box. I don't know if you guys know about those Patrols in the States.... I've never seen one there. I installed it a few pages back. The bolt pattern and the size of the box was all that differed but they mount the same way.80 box bolts to the out side of the frame so spacing the box out won't work.
There’s a lot of work to make a 4 door 40, hanging the back doors was one of the hardest things to me. Getting the lines right was next to impossible on my build. Still not right but they work. Until it snows…The back doors are back on but a few adjustments need to be made to the top to be able to mount it to the upper rear panel . Hopefully Monday, the top and rear panel will also be on.
No doubt especially if you have hand made door skins. I thought i'd never get to thi point but looks like we'll be ok.There’s a lot of work to make a 4 door 40, hanging the back doors was one of the hardest things to me. Getting the lines right was next to impossible on my build. Still not right but they work. Until it snows…
The Nissan Patrol was not imported to the North American market. You do see them here but there Gray market, have to be 25 years or older to import.What i have on it is a Nissan Patrol Y 61 steering box. It is said to be way stronger than the 80 series box. I don't know if you guys know about those Patrols in the States.... I've never seen one there. I installed it a few pages back. The bolt pattern and the size of the box was all that differed but they mount the same way.
They're everywhere here. Heck ..... I have 5 of them at the shop. I hear that their diffs are also stronger than the 80 series they're also wider.The Nissan Patrol was not imported to the North American market. You do see them here but there Gray market, have to be 25 years or older to import.
You do see them but there rare.
9.5" the rear is pretty stout. The 8"in the front of the 80 leaves a bit to be desired. Not hard to be stronger then that.They're everywhere here. Heck ..... I have 5 of them at the shop. I hear that their diffs are also stronger than the 80 series they're also wider.
