lelandEOD
I've been trying to diagnose an unusual problem with my 3FE for over a year. I've replaced almost all ancillary components that could cause this problem and have yet to find a solution.
Here's what it's doing: Warm or cold, I notice a slight hesitation/stumbling/sputtering as I accelerate through the RPM range. This isn't a violent loss of power or obvious miss but rather a subtle degradation of power that occurs from about 2,400 rpm all the way to 3,500rpm. At a very specific point, usually right at 3,500 rpm, it's almost feels like I flipped on a supercharger or something because the engine really comes alive. The loss of power is only noticeable under load (it free-revs fine) and is usually accompanied by a barely audible change in the exhaust note that can be best described as a mild buzzing or fluttering sound.
For the longest time, I was convinced this was a fuel pressure/supply problem. Last week, I bit the bullet and replaced my entire factory fuel system in favor of an aftermarket Tanks Inc. pump set up in the Con-Fer tank I've added to the rear. I've simplified the plumbing and am confident I'm supplying the needed volume and pressure (free of leaks that could introduce air into the lines) and I'm still getting the same hesitation symptoms at mid range.
Has anyone ever experienced something similar in their 3FE?
