- Thread starter
- #41
I really haven't been following this, so I'll ask some basic questions. If it's been covered please forgive me.
Have you verified proper mechanical operation of the throttle cable?
Have you verified proper mechanical operation of the throttle valve? IOW, without power applied, does the throttle plate fully close and come to rest on the endstop? Does it open all the way to the endstop and operate smoothly throughout the range?
Is the dashpot stuck in an open position?
It all has to all work properly mechanically first. Remember 1986 technology. If there's a piece of carbon on the intake preventing the throttle plate from closing, or any mechanical fouling at all, the electronic adjustments go right out the window. It's not smart enough to know the difference.
Thanks for responding Jon. Here are answers to your questions:
1. Throttle Cable is working properly
2. Throttle valve is operating properly and resting on the endstop when no throttle applied.
3. The dashpot appears to be working properly, but I'll double-check it
I removed the throttle body and cleaned it really well. The plate appears to be opening and closing properly and there are no obstructions.
The most intriguing thing I've experience is when i remove the air hose from the IAC valve. When its removed from the IAC and then plug up the IAC and the air hose, the idle drops down to near normal.
Would this indicate that the IAC is not functioning properly?
