- Thread starter
- #21
Not sure if I've gone down the wrong road or what, but can't seem to diagnose my issue. After cleaning, calibrating and bench testing both the TPS and the ISC. I decided to reinstall and pray for a solution. As a note, I made sure that the ISC was fully extended (closed) when I reinstalled it. I then buttoned everything up and made sure all vacuum lines and coolant lines were properly installed.
I cranked it up and the high-idle seemed to have disappeared. I was excited! I decided to drive her around the block and give the ISC a chance to adjust itself. Well, after a 3 minute drive the idle was back up to 1600...back to square one.
So, after not sure if this means that the ISC has opened up again during the drive and just isn't responding properly or what? It passed all the bench test regarding the resistance and it did move when electrified although VERY little. Like 1/8" rotation. Seems like it should be moving more.
Anyone have an idea of how I can get a more definitive diagnosis? Again, this started with a high-idle and a Code 51, which indicates some sort of switch issue or TPS. TPS checks out and was replaced within the last 2 years.
@jonheld I hate to call in the cavalry, but any thoughts or advice on how to diagnose?
