2F serial number info... (1 Viewer)
FJ40 Aug 1976
FJ40-230119 frame/body VIN
Motor 2F-108838
Appears original
Pics of where to find serial on engine plz
Passenger side of block above starter:
1900069
Peru delivered original FJ40, best guess April 1984 based on cylinder head code stamp "4 61010 0430" (if this interpretation can be verified I would appreciate confirmation).
Build year: 1984
Frame# FJ40-369731
Engine# 2F 830778 (model 11411-61013)
Model#FJ40LV-KC
Color Trim# 033 LK11
Trans.Axle# H41 KO52
Plant# A11
So does this count? Not mine yet. Hopefully will be by end of next week here in Bogota, Colombia:
1977 FJ40
2F192394
FJ40254758
In fact, since I’m limited down here it would be great if any of you experienced gents could tell me if this is good to go. Thank you.
Feb 1977 FJ40 high altitude model
VIN: FJ40-243547
Engine: 2F 152478
Vehicle IN = FJ40 ~ 225017. Plated date of manufacture is May 1976.
Head - Engine cast date top number = 11411
Block - Engine cast date bottom number = 61010 [ I am reading this as 1976 10th of October ]
Engine S/N = 2F 012773
Not certain if the engine is original to the truck.
Toyota FJ40
Oct. 1973
VEH. IDENT. NO. FJ40161504
Eng. Serial # F 513118
Lower Block # 60032
I don't see a 2 after the F. I've attached the pic. I also can't find the frame #. The front bumper has been modified so I hope it's not under a welded plate on the frame.
1973 Model Yr.
Date of Manf = Dec 1972
V. IN = FJ40141542
F155 s/n = F 419840
If you have an original 2F in your 40 or 55, please post up your engine serial number, and the month/year of your truck build and the vin if you would. I am trying to complie 2F year data.
I will be posting this up in the 60 section as well.
Thank you for your help! :beer:
-Steve
What is the purpose of the 2F Year Data?
2F 3222xx ; can't make out the last 2
Here's the interesting dilemma - I took this out of my 60 as I started the restoration, had it bored .030 over, put in the Man-a-Fre cam, found Man-a-Fre headers, desmogged it, found a Weber 38 - and found out, when trying to put the Saginaw steering pump bracket on - this block was missing the bolt holes that are present in the 2F appropriate for my 87 60. After some digging, I've discovered I have a fresh, built, desmogged pre-78 2F engine (so I am told) not made for my truck, which was the whole idea of the restoration.
Geez.
Anyone doing a 78 or earlier resto that is looking for a fresh original engine, complete?
Here's the interesting dilemma - I took this out of my 60 as I started the restoration, had it bored .30 over, put in the Man-a-Fre cam, found Man-a-Fre headers, desmogged it, found a Weber 38 - and found out, when trying to put the Saginaw steering pump bracket on - this block was missing the bolt holes that are present in the 2F appropriate for my 87 60. After some digging, I've discovered I have a fresh, built, desmogged pre-74 2F engine (so I am told) not made for my truck, which was the whole idea of the restoration.
Geez.
Anyone doing a 74 or earlier resto that is looking for a fresh original engine, complete?
FJ43 December 1983
Frame #FJ43112854
Engine #2F796215
Bogota, Colombia
edit: more info
