Dear All,
I need an expert to look into the matter as it has created lots of confusion and I do not want to redo the head gasket job again, so please advise.
I have 2F Engine and recently Head Gasket gone bad. As a normal procedure we replaced with after market Gasket. After Gasket installation engine runs successfully, during test run I observed some bubbles in Radiator, therefore, as suspected we open the Head again and check the gasket for possible cause of failure. I was astonished to see that, the Gasket was burnt from some areas and water marks appears on some areas where no water hole present.
Then, I looked at my old gasket (See the attached pic, on top) the old gasket has some manually created holes and we didnt do these holes as per understanding that the Engine is 2F and gasket is for 2F Engine. Now, I bring another gasket (pic C, the last Gasket in the pic) that has all the required holes and seems satisfactory but it created another confusion the HEAD belong to "F" Engine and head swap b/w F/2F and 3F is possible.
So, please take a look at attached pic and provide your feedback.
