Builds 2015 Base Build (1 Viewer)
It took 5 hours, but got those coils out without a spring compressor.
I removed the shocks, compressed the opposite side with a jackstand underneath and used a jack to push the axle down.
Once I had the right jack on the axle I had it all done in 45 minutes.
Truck drives much better and it's sitting nicely with just a bit of rake.
Rear suspension cycles better, as well.
Truck deals with wind a lot better and has had a noticeable jump in mileage.
  • Like
Reactions: r2m
Looking at getting Marlin Crawler 60" Universal weld on sliders.
Also, the center of the top of my wheel well is at 36 1/2 in front and 37 in back. Drivers side is slightly lower by maybe an 1/8".
Currently running 275/70R18 on OEM alloys
Absolutely love the 285-75r17s. They rub. But its drivable, and outstanding on the trail. Would be possible with anything but oem wheels with +25.
I have a bid for an Ironman Bumper and getting one for an ARB. I would prefer the ARB. Just needs to not be twice the price.
Is the move compared to the 70”? Also, can you install these with kdss? If so, a nice affordable option.
I think i have shifted to 4x-inmovatiojs 4runner weld on bars. The legs are not welded so they can set them where they need to. 4x has DOM with square main tubes available as an upgrade with some nice top plates
As far as length, 70 would probably be too long. I was going with between 60 and 66 to allow plenty of room for big tires.
We have a 109" wheel base and with 34" tires that leaves 75" then throw in few inches kf clearance plus the scrub radius/king pin radius you get 66 and if you want more clearance, 60.
Do it, Adam at 4x Innovations does great work. He built the sliders for my Baja T|X Taco with zero offset and expanded steel filler plates without batting an eye.
That was 13 years ago he was in Iowa then but has since moved back across the River to Wi.
Good to know. I am crossing that threshold of needing legit s*** as I start doing more advanced trails with more jeopardy.
That's what I'm talking about! WIDE sliders one can actually get a good foot hold when standing and prevent knuckle heads form opening their car doors on you in parking lots!
Ordered an RCI fuel tank skid
  • Like
Reactions: r2m
RCI fuel tank skid arrived.
I have a back log I will start working through tomorrow.
Probably doing a Lil Bs front bumper when they release their headlight loop model.
Getting Sliders from First Choice Fabrication. 303welding.com
Bumper is out, LFD winch mount is in and should be shipped soon.
Getting measured for sliders on Monday
Getting a BMC in 2.5 weeks from Tru Automotive in Denver.
Update:
Installed LFD winch mount
Cut bumpers
First Class fab welded on Sliders with kick out
BMC is done
Ordered:
Generic turn signals to delete the oem turn signal and cut the front bumper higher.
Warn VR10 winch. Will immediately put a synthetic rope on it. Probably the Badlands 12k.
Considering:
Icon wheels with bead retainers
Mid travel upgrade
Force articulation setup for when the KDSS 💩 the bed.
Pics please!
Also included pics of the turn signal lights i am testing out to replace the oem front. I dont know how many I will need to get the resistance so it doesn't fast flash without cheating and using a resistor.
The wheels are the "novel" DOT legal wheels with bead retention set screws.
Wow! Someone's been a busy little beaver! 😆
Yup, took some time off. I have a pretty massive backlog of projects.
Ditto.
Rig looks good. Did you take any pictures or can you tell me where you trimmed the rear bumper because I desperately need to trim mine. Or maybe I can give you a call and we can talk about how you did it and give me some details.
