2020 GX460 Build Recommendations
I think with my snow tires I had basically enough clearance to allow for snow buildup when snow wheeling. I have a set of 275/70R18s on oem alloys and they just clear the body mount by like 5-10 mm, just.. and that could just be my alignment and it can rub on most other trucks. If they cant get you there with an alignment, (which i doubt, thats over an inch compared to when I was.)
Scrub radius is a real PITA. I am mechanical engineer and still **** it, myself, on my first few builds.
So did I screw up by getting the -15 offset? I thought I needed it for the tires to clear the UCA assembly…I know a lot of folks with same GX and tires without this issue
Get an alignment and have then push everything forward if your lower UCA isn't seized.
I have been rubbing in my UCAs for 3 years and about 50-55k miles. I was commuting with it across the Pawnee grassland.
I have never gone wider than a 285, though.
Will do, but this is not UCA rubbing, it’s lower body where the shock assembly fits in
was it here?
Yeah, you can see where I’ve got the fascia pulled back by those yellow zip ties but at full turn the tire is rubbing on that metal body section ever so slightly. Pic is taken from the ground looking up. I haven’t driven around since I did the zip ties so I’m not actually sure how much I cut down on the horrible sheering noises of the fascia rub and if that metal rub will even be super noticeable but I’d prefer to avoid rubbing of course
Thats the body mount. Its hard to photograph. I just got my body mount chop today.
Any of the liner or step that rubs isn't a big deal but the body mount will damage tires. It did a number on my yokos. Missing a few lugs and will probably lose a few more. Lesson learned, will get the 4Runner a BMC before going bigger than 33 on oems.
Ok, so when folks are saying BMC they’re referring to this too? I thought it was just front fender rubbing they were talking about. Wondering if that alignment plus the extra lift from 1.75” to 2.5” will help and can avoid that chop
Alignment might help, lift won't. I ran that size on no lift for almost 2 years. You wont have issues hitting the top of the wheel well until you go to 35s. Everything you will hit is in the front and back of the wheel well.
Same size with no lift? Dang. Did it not rub or did you not mind it? Mine looks like it’ll only be an issue at full wheel turn anyway. Just annoyed it’s even happening.
It only rubbed on plastics. I didnt get BMC rub until I had 285-75r17s.
Alright. Wonder if it’s my negative offset then
Thats not helping. I think for every 3mm of offset you increase the scrub radius by 2mm. So lose 2mm of body mount clearance.
Here are some pictures I grabbed of what my BMC looks like. And the chunks missing from my tires. I am customizing my tread, apparently. 😂
You need a BMC to run the negative offset wheels. When I ran 285/70/17s on 17x8.5 +10 wheels it would just clear the body mount by a few mm. I switched to 17x8.5 -12 wheels because the +10 would rub on my relocated swaybar brackets and had to get a BMC.
Yes, thats a lot of negative offset for a 33. Those take way more scrub radius than my 34s on oem steelies that are + 25.
In a J150 IFS lifting doesnt increase clearance. That's something from solid axle trucks. You will need to push liners and for sure do a BMC with that wheel tire combo, and I pushed the big tire no BMC game further than anyone.
Agreed! Go to a shop that does off road Toyota alignments and have them move the camber forward, that'll fix it.
This is the route I’m going. Keep track of the added weight over stock after adding armor so you can get the correct springs for the lift.
Current
255/70/18 BFG KO2s>JW Offroad tire carrier>Roof rack>Removed 3rd row, Added 3rd row platform>Bumper trim>Added RCI engine, transmission, t-case, gas tank, and catalytic converter skids
Future
Sliders>Victory blitz bumper>Suspension
Love to see a picture
Well, here she is in all her glory. Mickey Thompsons on aftermarket rims, Dobbins 5100 2.5” rear and 1.75” front with Victory 4x4 front and rear armor. Still have some things to do like skids and sliders. Going to keep the roof rails for now because I doubt I’ll use a platform rack too much.
It’s been great!!
It’s been great!!
Love the "dirty" pictures!
