Hiluxforever
- Thread starter
- #61
Pic of the front with some dirt from a B Road near where I work.
Now it'll be like a truck with a pass-through shell!Discussed it last night and I am going to pull the second row as well.
Which was kind of what I wanted to begin with.Now it'll be like a truck with a pass-through shell!
Albeit, a very comfortable truck...
Nice van!
Omg it's so loud.Nice van!
Didn't even consider the added noise now all the sound deadening seats and carpet are out!Omg it's so loud.
It's like having a window or two down, that's how much louder it is, so there is definitely a minimal amount of dynamat to do, to try to get that back.
Also, holy s*** there was a ton of dog fur. Husky life.
Hey! IF it works, good on ya! No need to waste money if it can be done with equal results (or acceptably close results) but less cost.
There are caps you can get to replace the hanging third row seat belts on the D pillars.Second round of sound deadening made a noticeable difference. I also used it as an opportunity to pull loose the 3rd row seat belt.
I did a non scientific knock test to determine where to put and tried to cover the wheel well thoroughly as well as get the back side of the panels through the access hole. The duct from the ac unit can slide up and off to get behind it.
I have get enough energy back after dinner will do the driver side and if I have enough energy and maybe the tail gate.
Thanks! I had seen that mentioned. It's on the list that seems to get bigger and not smaller.There are caps you can get to replace the hanging third row seat belts on the D pillars.
A lighter solution for floor panels may be corrugated plastic sheet, about 0.5" - 1.0" thick. It's light, resistant to most all chemicals and UV, mold resistant, water proof, easy to work with and relatively cheap if you can find it as a single sheets.Thanks! I had seen that mentioned. It's on the list that seems to get bigger and not smaller.
I am fully re-evaluating my build plans now, and am looking at lighter solutions. May not change anything, but worth looking.
Thanks, what kind of loads will it take before collapsing?A lighter solution for floor panels may be corrugated plastic sheet, about 0.5" - 1.0" thick. It's light, resistant to most all chemicals and UV, mold resistant, water proof, easy to work with and relatively cheap if you can find it as a single sheets.
Here's an example of what I'm talking about: Corrugated Plastic 10mm coroplast corrugated plastic sheets, coroplast plastic corrugated sheets, 10 mm black, red, yellow, 24 x 24 white, 48 x 96 corrugated plastic sheeting - https://corrugatedplastics.net/10mmCorrugatedPlasticSheets.html
