200 Series Tire and Wheel Size Database (13 Viewers)
I agree, with those offsets (suboptimal) @ 28lbs may as well go for the trd bbs forged 18s. I don’t see the point. The trd is oem Japanese for the purists too, which I like in theory myself.
Not to gloat but I’m on 23lb 17s with a load rating of 2500lbs offset +25. Only drawback is id wished for the additional 10mm of offset. I’m sitting on these wheels I’m glad I got the fifth before they went out of production.
Everyone should be giving method their business IMO. Every single spec is listed with no goose chasing on their website. I’ve posted screenshots multiple places. We need to reward consumer friendly businesses.
Where is the link for the spreadsheet? I didn't see it at the beginning of the thread, and have read quite a few pages.
I am getting ready to install the basic OME 2" lift, planning on running factory wheels for awhile and trying to select tires.
275/70/18 Falken Wildpeaks are ordered but I have the ability to change directions and need your help. Will I have rubbing issues? If so, on what and what are the options to correct? Should I order the slee wheel spacers to get more clearance?
Or is 285/65/18 a safer route. I don't want the tires to look silly if they don't fill out the wheel well...
Thanks, Chris in SLC.
This is the latest link i've seen for it. Wish a moderator would put it in the first post.
Copied from the above post to save clicks:
That's the first time I've seen that database! Here is a new version (data can be sorted/filtered on the appropriate tab). Add additional data through the survey here.
I'm in SLC too- 2016, fully stock right now. Had Falken wildpeak AT 275/70/18s installed on stock wheels last week and getting the coil spacer installed at LHM Toyota tomorrow (hopefully). Without the spacer there's a very light rub at full lock turned left. I assume it is the mud flap.
Discount tire almost didn't want to install the tires because they were sure they'd be too big for the wheel well but I assured them it'd be all good. They were amazed they fit after installing but still had concerns about kdss rubbing at full right lock but I haven't had issues with that.
Haven't wheeled or gone full articulation
Snowy pic is before. The rest are after.
The guy before me had 265/65/18s Toyo open country on it so were pretty measly
Lol DT wouldn’t order my wheels and tires either for the Lexus. I made personal reassurances they’d fit and paid up front.
Those look great. I little forming/trimming I am ok with. Thanks for pictures and feed back. I will post up as soon as I get mine done. I'm still waiting for UCAs to come in before dropping it off for the install.
Now with OEM coil spacer installed. Was in the 500s all in- with parts, labor, taxes, alignment.
This is all the height I need. Debating wheel spacers now
Does anyone have experience with good spacers that are less than the standard 1.25" ?
Bora 1” or Spidetraxx 1.25”. Don’t use anything else or anything smaller.
You’ll want the Spidertrax 1.25” if you want a flush look.
That looks really great, I look forward to seeing you around. Most days I'm driving my tundra, but on the weekends I'm in the 200.
Definitely agree
I just wonder how much extra dirt and salt slinging that 1/4" would save me on dark paint
If only I had gotten silver or white...
It doesn't sling much more than without them in my experience.
Can’t find a wheel set that like that fits the way I wanted. I’m trying spidertrack spacers. Here is before and after, is this a bad idea? All of the 9 inch wheels with 25 or less offset are to wide for my taste. Any suggestions would be great.
So you want more poke? Icon make some +25 offset. Then there are lots of tundra fitments in +18, 0, and even -values.
No, I want the same as now. The only wheel I have found that is close is the Oz rally raid but would poke out another 10mm.
Ah, so wheels in the 40 to 25 offset range.
Alphaequipt has +35 in 17@ and +25 in 18”
Method has +35 in 17”. Icon has +25 In 17”.
Or a 1” to 1.25” spacer on stock 60mm 18s.
Evo corse has a size with this offset as well.
