- Joined
- Jul 22, 2012
- Threads
- 576
- Messages
- 16,188
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
how is the suspension working?
Aight, I put my thinking cap on and came up with the obvious fix for the ass high aspect.
These springs come with 2 spacers that are only there to fill the gap for a standard Ubolt setup to work. Without them most units would possibly bottom out and not get fully tight.
This is a real issue with Dobinsons springs because most ubolts are made for thick OEM packs.
So....simply move the spacers from the bottom of the pack to the top.
Instant 1" lower.
Tagging @orangefj45 for a tech tip
I was going to say, I wouldn't be surprised if there is some engineering reason for the location of those spacers and you'll need to move them back.
It's like you have a piece of wood in there now for some hill-billy lift action.![]()
One thing about the 70 is the sliding side/ rear glass on these trucks lets in a lot of noise. The MTs, even new give you a bit of unnecessary cabin noise unless you really need an MT
Our FZJ70 is very quiet even with the windows open and MT tires under her. The driving environment is more like a street sedan rather than a Cruiser.
Due to this, I look forward to an opportunity to road test your gem and experience true quiet from your attention to detail.
Its not often you see people put lowering blocks into a landcruiserhow did tie the spring centrebolt up into the locating hole in the axle perch to stop the axle moving or sliding around
Sweet rig! How does the lift increase from the parabolics compare to what you might get from a set of 3" OME's (like CS004/5) or Dobinsons?
I need to replace my tired OME springs and am thinking of going for parabolics, just need as much height in the back as I can get to help stuff my 35s.
