- Thread starter
- #201
Is the AC system over charged? That could explain the on-off-on-off of the compressor and fan too.
Worth a try, it is just a plastic threaded plug. Sorry to hear that recoring the RAD didn't make the temp issues disappear altogether. That can be pretty disheartening. I can't remember, have you tried an acid wash/flush to clean out all the passages in the engine block? Provided your water pump is functioning as normal, perhaps the flow is being restricted?water temp woes continue.. I think my coolent system isn't holding pressure. Climbed under there last night and saw this from the drain plug on the bottom of the rad (I assume this is a drain plug?)
It doesn't do this constantly, but I did finally catch it at least. Is it safe to teflon tape that little guy?
the 13-bt just got rebuilt this year, so the engine internals should sparkling. I think my main problem is this crappy spal fan and lack of a shroud. I could be imagining things but I do think the re-core helped, but now that the drain plug is leaking I'm losing coolant and not holding pressure in the cooling system, which is making it easier to boil.Worth a try, it is just a plastic threaded plug. Sorry to hear that recoring the RAD didn't make the temp issues disappear altogether. That can be pretty disheartening. I can't remember, have you tried an acid wash/flush to clean out all the passages in the engine block? Provided your water pump is functioning as normal, perhaps the flow is being restricted?![]()
Like @AirheadNut said, check for the o-ring as well. But yes, if there is no shroud and OEM fan, I would look at getting those installed as they would make a huge difference for sure. Sealing the shroud with some foam to make sure the air is getting pulled through the radiator will help as well.the 13-bt just got rebuilt this year, so the engine internals should sparkling. I think my main problem is this crappy spal fan and lack of a shroud. I could be imagining things but I do think the re-core helped, but now that the drain plug is leaking I'm losing coolant and not holding pressure in the cooling system, which is making it easier to boil.
unfortunately the way the 13bt is mounted in there, I'm going to be stuck with electric fans. The fan-clutch is off-center to the rad and not square, but angled about 15 degrees left to right, so no oem fan for me. I think there's a pretty vast grey area between what I have now and a top-of-the-line electric fan setup though, plenty of room for improvement.Like @AirheadNut said, check for the o-ring as well. But yes, if there is no shroud and OEM fan, I would look at getting those installed as they would make a huge difference for sure. Sealing the shroud with some foam to make sure the air is getting pulled through the radiator will help as well.
The 13BT fan comes off set from the factoryunfortunately the way the 13bt is mounted in there, I'm going to be stuck with electric fans. The fan-clutch is off-center to the rad and not square, but angled about 15 degrees left to right, so no oem fan for me. I think there's a pretty vast grey area between what I have now and a top-of-the-line electric fan setup though, plenty of room for improvement.
yah, but it's engine-swapped into an lj78, which expects the fan to be left about 5"The 13BT fan comes off set from the factory
Seems like that is how the 13BT was off set too if I remember correctly. I don’t have mine anymore unfortunatelyyah, but it's engine-swapped into an lj78, which expects the fan to be left about 5"
it would be amazing if I could get a clutch fan in here... Not sure how to verify, I suppose I'll have to get to a meetup somewhere.Seems like that is how the 13BT was off set too if I remember correctly. I don’t have mine anymore unfortunately
I can check mine tomorrow to see how it sits.it would be amazing if I could get a clutch fan in here... Not sure how to verify, I suppose I'll have to get to a meetup somewhere.
