1989 4Runner R150F Rebuild
Ojai, Ca
Last December I went on an awesome trip to Death Valley With the family. We took the 4Runner of course. Four adults in a 1st gen is a tad cramped for a long trip like that...
...anyway, on the way back, about 20-30 miles north of Mojave, 5th gear disappears. Uh oh! Downshift to 4th and cruise into Mojave. At the stoplight I discovered I also didn't have 1st, 2nd or 3rd!
I quickly put it in to low range and 4th and limp to the gas station, and discover no reverse either...
I drove the rest of the way home to Ojai in 4th gear, swapping between low and high range.
When I pulled the transfercase off after removing the tranny from the truck, a bunch of oil dumped out from the void between the two. Apparently the transmission output seal failed and dumped it's oil in there, thereby running dry and toasting the input and countershaft.
258,000 miles and almost 33 years.
I spent January rebuilding the transmission and transfercase, with some upgrades
New Bearings, seals and syncros
New clutch, flywheel, pressure plate, rear main seal
New master and slave cylinders
AX15 2nd and 5th gear (and countershaft)
Marlin Crawler shift forks
I have since put almost 3000 miles on the rebuild, including towing a small U-Haul (after the break in period).
The higher 5th is great for cruising, and the lower 2nd is nice for those slow roll stop signs.
During my research I did find a Toyota part number for a countershaft that could have combined the AX15 5th gear with a lower 1st instead of a lower 2nd, but was unable to source it. Oh well...
Pictures!
This was definitely the most challenging vehicle project I have done, but it was totally worth it. The gearbox is no longer a mystery and it shifts like new!
I was getting 16 to 17 mpg, but recently got 18 mpg cruising up to Modesto from Ojai. New bearings, new oil, or higher 5th or some combo of all 3? Who knows...
That is fantastic! I took a W56 apart just for chuckles and grins and was way intimidated by it. Even with the FSM I'm not sure I could have confidently rebuilt it. Where did you get the AX15 idea?
The trick is to take LOTS of pictures, and also bag and label everything!
I don't remember exactly where I first read about it (probably Pirate4x4), but the R150 and the AX15 were both made by Aisin-Warner and share most of the same guts. I have 5.29's on 33's so I was looking to bring the RPM's down on the highway.
Nice job! What oil are you running? I noticed "notchy" shifting with GL5 and smoother shifting with GL4 in my R151F/R150 hybrid. Redline MT 90 also shifts smoothly.
This time around I am running Redline Heavy Shockproof (looks like Pepto-bismal) switched back to Redline MT-90 after ~7000 miles in the transmission and Valvoline 80W-90 in the transfercase, so far so good. I used to run Redline MT-90 in the 4Runner (I still do in my MR2) and it worked great too.
I just got back from a twelve day, 3894 mile road trip to South Dakota and back with no transmission issues. Judging by feeling the gearshift, the transmission seems to run cooler now than before.
I've switched back to Redline MT-90. 4th gear started popping out occasionally while shifting lazily. Upon further reading on Redline Heavy Shockproof:
  • Not recommended for most synchro applications due to the product's extreme slipperiness
I've only done one test drive since switching back. It definitely pops out less, but still sometimes.
Whelp... It's out again...
The damage was done, and repeatedly trying to hold it into gear only made things worse (Duh!). Leave it to me to destroy a Marlin Shift Fork.
At least it's a good excuse to put in the Marlin's Heavy Duty Bearing Retainer while I'm in there this time!
you figure out what was making it pop out of gear?
I think initially it was the shockproof oil being too slippery, causing the synchro to not line up properly with the input shaft, preventing it from getting fully into gear. If I did manage to get it into gear by rev matching or dumb luck, it would stay in gear and not pop out. It started right after I put in fresh shockproof oil after my road trip.
Well that sucks. Sorry to hear. I noticed "notchy" shifting when I used GL5 instead of GL4. I had a lot of people telling me it's not the problem. I went back to GL 4 and no problem since. I used Sta-Lube for a while and I'm currently using Redline MT 90.
I also was told to make sure to scuff up the wear polished surface where the syncros contact to prevent notchy shifting. I thought I didn't scuff it up enough at first but, the GL4 did the trick. It's been a few years and many miles trouble free so far. I also used Marlins upgraded parts like you have and OEM bearings, gaskets and syncros.
I hope you don't have too much damage and get it back together soon.
About to rebuild a grindy 3rd gear r150f myself. Are there year break ax15 gears and counter? With the pre 95 r150 I think there are year breaks for bearings and maybe synchros. I'd love to do this upgrade.
