1987 FJ60 (Engine Help/Question)
Steamboat
I have a 1987 FJ60 4 Speed Manual. I'm in Colorado. Overheated on Sunday. Thought it was the Thermostat (which it was - stuck) but turns out after they did the Combustion Test it was confirmed the Head Gasket is blown. Jasper apparently doesn't made 1987, 4.2 Engines anymore. The only place that does is only warranties a new engine for 12 months (wild)
Cost of the Engine quoted is $5075, $500 to ship. 19 hours of labor for a total of $10,280.
My question: Should I just replace the Head Gaskets and look around for an engine somewhere else....or sell it?
Trying to debate smartest option. Truck picture below is from Sunday. Thanks for your input.
Agree ☝️Just replace the head gasket and don’t look back and enjoy going forward 👍
Agree with the above. If you've got a driveway and basic tools, replacing an HG is not too bad. It's work, but when you get down to it it's mostly just unbolting/bolting. This forum will have all the answers you need.
If you want to pay a shop to do the HG, that's cool too. It won't be cheap, but it def won't be $10k.
Just swap the head gasket. I had an old 1980 pickup with a 20R that overheated when I blew the head gasket. I took the whole head off with the intake still attached, slapped a new head gasket on and it's still running around 7 years later. I didn't clean the top of the head or anything as I didn't know any better, so moral of the story is these engines are pretty robust and you should be fine.
If you do decide to replace the head gasket yourself once you have the head off take it to a shop and have it checked for cracks, resurfaced, and a valve job.
Concur. Valve job is just routine maintenance. Maybe shave the bottom just a hair for a little better compression, which helps at altitude. Take your manifolds too, have the mating surfaces trued. While the manifolds and head are there, probably should port match them too. Traditionally, you could get chevy valves put in to a F head, don't know if it works for your head. I even got some LS valves so I sorta did a very small LS swap. They were having trouble finding some LandCruiser valves when i got my valve job, 2 yrs ago or so.
Doing your own head gasket is another of those Rite of Passage things, like knuckles. Just heavier and more expensive. You'll probably need some new tools, and you'll be saving a fortune over shop rates. You can do it right with 'Mud looking over your shoulder.
Use only a genuine OEM Toyota head gasket. Rest of the gasket kit doesn't matter so much, but the Toyota head gasket is vastly superior to any aftermarket.
I can't get access to the parts anywhere: 22 sites say they have them, when I put them in the cart or speak with service, no one has them. Anyone have an idea who stocks lots of parts:
Cylinder Head:
https://toyota.oempartsonline.com/oem-parts/toyota-cylinder-head-1110161040
https://toyotaparts.lakelandtoyota.com/search?search_str=11101-61040
Thermostat Housing:
https://toyotaparts.lakelandtoyota.com/search?search_str=16331-61032
https://www.moderntoyota.com/parts/...em-parts/toyota-thermostat-housing-1633161032
Cylinder Head:
Thermostat Housing:
https://www.moderntoyota.com/parts/parts-catalog/?path=/oem-parts/toyota-thermostat-housing-1633161032
Call Cruiser Outfitters - they'll get ya taken care of. Here's the head gasket set:
I stock all of the normal parts needed to do a head gasket job, new OEM
We would love to help!
We have OEM or Japanese head gasket and/or engine overhaul kits in stock and ready to ship. The EGGK61040 you linked is a great kit, made in Japan. We've sold and installed many of them over the years. I'll be putting one in my blue 72 40 (with later model 2F) shortly.
I actually need the Cylinder Head though as well.​
I missed that part. Head cracked? We have good core 61040 heads available as well.
