- Thread starter
- #81
A few months ago, I purchased a set of early/mid 1990's 70 series axles (both front and rear) with factory Toyota E-lockers from Barry (OilHammer).
The front is a 70 series high-pinion axle with factory Toyota E-locker and 4.11 gears. The axle is set-up with leaf spring mounts (it came with the leaf spring mounts from factory) and electric locking hubs.
The rear is a 70 series Full-Floating rear axle with factory Toyota E-locker and 4.11 gears.
Since my truck did not come equipped with the electric locking hub wiring harness, I will be replacing the electric hubs for a set of standard AISIN manual locking hubs. After reading many threads about buying adapter plates to install manual locking hubs, or modifying the stock electric locking hubs to activate manually, I called Wayne (crushers) and had a quick conversation with him about this.
https://forum.ih8mud.com/70-series-tech/327662-lj78-prado-axle-service-how.html
Wayne mentioned that since I had all the parts from the old (9.5" axle) I could change from the spindle out and keep my current AISIN locking hubs. The spindles are different (electric vs. manual) but the bolt pattern to the knuckle are the same.
By doing all this work, I would gain:
1. Both axles with 4.11 gears (my current axles have 3.73 gears)
2. Factory Toyota E-lockers front and rear
3. Full-Floating rear axle
I know that this will generate some differences in opinions as I will be replacing a stronger 9.5" front axle for a smaller (perhaps weaker) 8" high-pinion front axle. However, my reasoning for doing this, is that I purchased the whole axle (assembled) with e-locker and gears, and this truck will be dedicated for mild-medium duty trails. I have a BJ40 in the garage waiting its turn to be modified that will be designated for severe-hard duty trails. I will keep the 9.5" front and rear on the BJ40, but will go along with the high-pinion for the front BJ70.
