Alright, I'm going to give you all the information I have on this.
But first, can anyone tell me what voltage/amperage triggers the charge light on a 60-Series?
For the basis, this is my 1983 60, and I've run a trouble free 31,000 miles on this setup. I have to 80A 3FE Alternator adapted with the correct plug from @Coolerman.
Again, I daily drive this truck with no issues on this setup. Yesterday however, my family and I drove to West Sixth Brewery's farm about an hour from the house. It was hot, so I cranked up the AC (first time this summer) and we cruised along happily towards the farm. As you do in a 60 series, I had to stop for fuel.
Filled up, no issues. Started back up and we had a charge light on solid. Dang.
I turned the AC off and nothing changed. Same amount of illumination at idle or at speed. At speed however, it does flicker slightly following the Volt gauge. Which still looks OK (I know these are notoriously inaccurate) but I'm showing good voltage. I can turn the headlamps on, no change. Rear heater, wipers, etc. No change.
BUT, if I turn the HVAC Fan on (AC or not) on the first setting the light goes very dim. Volt gauge doesn't change. As I turn the fan on higher and higher the charge light gets brighter.
I didn't have an amp meter on me and based on the volt gauge, we continued onward. We got to our destination with no issue and enjoyed our afternoon.
Leaving, we started up no issue. No slow cranking, everything seemed normal but I still have the light.
We drove back home an house with no issues. Thank goodness!
Once I got the wife home and our girls settled in I went back to the garage and got out my amp meter.
Battery shows 12.2V not running.
Start it and at idle the battery shows 13.4V and I get the same at the alternator post. I took everything apart, cleaned all contacts and reassembled with dielectric grease. Test again, pretty much the same voltage and still have the light.
Start it this morning, light still on, bring my amp meter to work, test in the parking lot and I have 14.4V at the battery and 14.4V at the alternator post.
So, what am I missing here? Does the charge light look for something above 14.4V? I feel like this is pretty decent? I feel the 13.4 might have been a little low but not out of question.
Or do I have an unwelcome gremlin? Did I mention the volts readout is the same with the vent fan on low and the charge light very dimly lit?
Thanks for your time!
