Builds 1979 FJ40 Preservation-ish Project (2 Viewers)
OPMACHINE
Supporting Vendor
Jacksonville, FL / Thomasville Ga
Cruiser Gods,
I have done a poor job of documenting my past projects, so for this impulse buy, I have decided to document as much as possible. This is my first 40 series project, it is apparent I will need to enlist the help of the MUD community. I have wanted my own FJ40 since i was a little kid. I found this FJ40 less than 5 miles from my house. I was BJANDCJ in a past life.
The lady in questions:
- 2/1979 FJ40 California spec.
- Sky Blue
- Dealer option Clardy A/C
The Legend:
Sold new in California, stayed until it was sold out of San Diego in 2009. From 2009 until 9/5/2019 is has been garage kept (car port last year) and driven 7,000 miles in the last 10 year. From the service record I have, it looks like it has been loved and fairly well maintained for the last 20 years
Current State:
The good:
- service records from 2000 thru 2019
- 2.5'' HFS CCOT lift. (no experience)
- SOR vinyl seats and cushions have been replaced.
- new OEM badges (originals saved)
- factory Toyota vinyl carpet (torn at driver right heel)
- most EVERYTHING works as it should
- very complete and original/ period correct
- good compression
- passed California smog in 2009 ( less than 8k miles ago)
* The transmission and t-case were rebuild in 2007 among other things. The work was done by Burbank Union Aurocare Center. * Anybody have any info on this outfit? (around 10k miles ago)
The Bad:
-The exterior was repainted the original Sky Blue before it was sold in 2009. Patina lost forever
- wrong front bumper
- There is rust on the rear quarter panels that has busted thru, zero signs of any previous rust repair or bondo.
- the clutch master cylinder leaking
- surface rust around the drain holes on the floor boards.
-surface rust on the inside of the hood where a heat shield had been stuck.
- A/C does not blow cold. (leaking hoses)
- steering box leak
The Plan:
I just want a solid original cruiser that is fun to drive. 95% I will have to top and doors off.
Preserve Patina:
-hot pressure wash the exterior and undercarriage (complete)
- sprayed rust converter on the rust spot on the undercarriage. (complete)
- spray fluid film in the body cavities to prevent rust from eating her from the inside out.
Change all fluids:
Change all hoses:
- California smog equipment looks like it will be hard to find parts for. I have been looking for the pump hoses? Please....
- Clardy A/C hose are leaking so i think i will replace with modern crimped hose or just shelf the whole ac unit or Vintage Air
Front and rear axle rebuild:
Fix Rust:
I am going to start with the right rear quarter first. I basically spent all of sunday scrubbing the bottom of the cruiser with CLR and a scotch brite pad, and i am pretty confident there has never been any previous rust repair.
-Who makes the best rear quarter patch panel?
- Any special techniques or prep work I should consider?
Pictures:
Nice 79! Not much needed on this 40.
I’ve been reading up on the Patina thread about slathering Fluid Film over original undercarriage and just running as is. Something I did not do with my ‘81 regretfully.
My OCD would want to attack the rear sill and quarter panels, but i would leave it at that.
