Working on the structure under the roll cage landing in the front corners
Stock
Mine
Awl_TEQ said:All 80 but I also use the maroon scotchbrite in the 2" and sometimes a 36 grit 2"
Awl_TEQ said:The goal was to minimize the loss of foot room so it is tucked about as far out of the way as possible.
My new favorite tool for grinding down the weld bead/tacks. I borrowed this one from work but I will be buying one eventually. It allows very accurate and fast removal of the bead without damaging the surrounding area or making a lot of heat. You have to keep the tool moving or you will dig a groove but with practice you can be very controlled. You can see the rib end patch at bottom right of the photo where I removed the bead flush. The tool is a Dynafile belt sander with a 1/2 x 18" belt in 80 grit. This brand is industrial strength and very pricy but you can get them a lot cheaper from CP and others.
