- Thread starter
- #21
This is very helpful, thank you. I'll give an update after the weekend.Happened on mine. Get the transfer case seal kit from SOR or City Racer, pull off the d/s and get after it. The coarse spline output shaft needs some FIPG or RTV to seal up properly after you replace the seal, or you'll get more oil coming through. Shaft itself should be fine, good to replace the shoes if you have them, mine were fine after cleaning them up, ymmv. Do the one on the front output as well.
Also can't believe I'm your first , what is this place coming to...
