Have read several threads of similar symptoms, but none where efi fuse keeps blowing.
Background... My rig is a 97 LX450. Was driving home from camping trip and died without warning. Was running good up til it quit running. Did what I could at 11pm with whatever car knowledge I had. Thinking back to that night I remember lifting the MAF connector wire and water spilling out of the protective sheathing (which worried me a bit that night). Called AAA and got home safe and sound by 2am that night.
Anyway... The engine cranks but no start, no CEL and here's what I have tried to date...
Put in new fusible link (original was butchered by PO. wonder how it ran to begin with?)
Put in aftermarket EFI Main Relay (ordered oem just in case & should have in cpl days)
Wipers, headlights, radio, etc. work. (read threads that said to check these items)
Checked 50A AM1 fuse for continuity and was okay.
Checked 30A FL Power fuse at dash for continuity and was okay.
Still cranks and no start no CEL.
Notice clicking when turning on key. Think clicking is coming from EFI Relay.
15 amp EFI fuse blows every time I turn the key (have not seen any other threads that mention this symptom).
Almost forgot, there is a 30A fuse that is blown under the dash. There are 3-30A fuses on three separate wires under the dash. The blown fuse is on a red wire (power I assume?) I trust no work that's been done by PO and don't know what's original and what's not, so not sure what these three wires and fuses are.
Your suggestions are greatly appreciated! Need to get running asap because I am moving in 5 weeks.
