looks pimp, cant wait to get one under my truggy, but I also gotta see if I popped both longs first...
Oh yeah, did you have the ring gear machined for the shave kit?
Did you do the gear set up? If so, how was that?
all the above is true. these axles are not the same
both have 10.5 ring gears but there different. both use 30 spine shafts
as well as the 11.5. the dodge one does not have the drop out pinion with the 3rd support bearing.
dodge 10.5 specs
1 of 3 widly used axles disigned by aam off of the corperate 14 bolt design
the second is the 11.5 and the third is the front 9.25.
the 9.25 was based off the semi float 9.5 14 bolt
Ring Gear Diameter: 10.500
Diff Cover Bolts:14
Ring Gear Bolts:
12 (M14x1.5 LH)
Axle Spline Count: 30
Axle Shaft Style: Full-Floating
Pinion Diameter: 1.75"
pinion Splines: 30
Pinion Support: No
Carrier Breaks: No
Dropout Carrier: No
Max Output Torque: 6,242 ft-lbs
Max Cont. Torque: --
Popular Applications:
dodge / Ram Power Wagon 2005 - 2010 Rear
Dodge / Ram 1500 1/2 Ton 2006 - 2011 Rear mega cab
Dodge / Ram 2500 3/4 Ton 2003 - 2011 Rear
Dodge / Ram 3500 1 Ton 2003 - 2004 Rear
Dodge / Ram Van 2500 3/4 Ton 2003 - 2003 Rear
chevy 14 bolt( corperate design, now aam)
Diff Cover Bolts:14
Ring Gear Bolts: 12
C-Clips: No
Crush Sleeve Yes
Pinion Diameter: --
Pinion Splines: --
Pinion Nut: 1-1/2"
Pinion Support:Yes
Carrier Breaks: 4.10 / 4.56
Dropout Carrier: No
Max Output Torque: --
References and Resources:
BillaVista 14 Bolt Bible
Chevy C20 / C35 1973 - 2002 Rear
GMC K20 / K35 1972 - 2000 Rear
GMC G15 / G35 Van 1975 - 1996 Rear
Chevy Suburban 1973 - 2011 Rear
Chevy Silverado HD 1999 - 2011 Rear
GMC Sierra 2500 1999 - 2011 Rear
Chevy Avalanche 2002 - 2006 Rear
GMC Yukon 2500 1992 - 2010
and for the hell of it heres the aam 11.5
Ring Gear Diameter:11.500
Diff Cover Bolts: 14
Ring Gear Bolts: 12
C-Clips: No
Crush Sleeve Yes
Pinion Diameter: --
Pinion Splines: --
Pinion Nut: 36mm
Pinion Support: No
Carrier Breaks: No
Dropout Carrier: No
Max Cont. Torque:--
Chevy Silverado 2500 2001 - 2011 Rear diesel
Chevy Silverado 3500 2001 - 2011 Rear diesel
GMC Sierra 2500 2001 - 2011 Rear diesel
GMC Sierra 3500 2001 - 2011 Rear diesel
Chevy Express Van 2004 - 2009 Rear diesel
Dodge Ram 2500 2004 -2012 rear diesel
Dodge ram 3500 2004-2012 rear diesel
all axles share designs and some parts but are not the same in any way. just like dana 60/70.
i have worked on all 3
yes the majority of the carrier parts are interchangable from the corperate 14 bolt and the aam.minus the pinion bearing.
my rear is a aam out of a 05 and has a posi currently from a late 80s with the stock 4.10 gears from the 80s.
the brake mounting plate on the axle is different due the disc brakes used on the newer version. obviously spring perches, shock mounts ext are different
wheel studs are metric 14 mmX1.5 threads on the new ones but still have the 8x 6.5 pattern
diff covers are the same but the new aams have metric bolts. my diff gaurd bolted right up with the correct hardware
yea sooo thats all i got for you off my stored info
edit: 2011 chevy changed lug pattern to 8 on 180. i havent seen a 10.5 in any truck locally all of them come with a 11.5 gas or diesel here. i dont know if the discontinued the corperate design 14 bolt or not maybe someone else knows
FUGGIN AWESOME INFO BROTHER!!!! Im contemplating getting an atlas...If that happens, a 14 bolt will be IN!!! KI'm in the process of building my 14b up to put into my 60 this weekend. It's nearly complete, so I'll give you some info. I'm not modifying my housing ( centered rear transfer case ) nor am I running 6 lug hubs, but I have gone through the rest of it.
1. The ballistic fab shave kit requires that you machine the ring gear. Their kit comes with a rear cover and plate for the bottom of the center section, which you cut off when doing the shave. More info here:
http://www.ballisticfabrication.com/14-Bolt-Shave-Kit_p_1728.html
2. Setting up the differential seems to be super easy. I did mine a couple of nights to go. Since the pinion drops out of the housing, you simply assemble it into the pinion carrier ( is that the right term? ), set the pinion bearing pre load ( PBPL ), then put it up into the housing with your appropriate shim between the pinion carrier and center section. Carrier Bearing Pre-Load ( CBPL ) and backlash are set with carrier bearing adjusters that are locked in place with a fork, one for each side. The full instructions for setting PBPL, CBPL, backlash and then checking your pattern are located here ( linked from the 14 bolt bible on pirate ):
http://www.pirate4x4.com/tech/billavista/14b_bible/14b.pdf
Finally, brakes. You can buy disk brake conversion kits for drum brake axles from Ruffstuff and bolt up disk brakes. However, what appears to be a better solution is to run the later model 14 bolt ( now called the Chevy / GM AAM 10.5 ) disk brake / e-brake setup. This leverages a drum-in-hat e-brake design that provides a good, reliable e-brake while providing disk brakes with a floating rotor. Super slick design. AAM 10.5 axles are beginning to get cheaper and cheaper. I got mine for $250, with calipers, rotors and 4.10 gears w/gov-lock.
One thing I haven't figured out yet is the brake line. The brake line on the T on this newer 14b seems to be larger than 3/8", so I'll figure out how to adapt that to M10 in the next couple of days.
Here's a quoted post from Pirate4x4.com that outlines the newer 1 ton axles:
Add me to the 14 bolt club.
Looks awesome under there!
