100 Series Cupholders, Dome Lights, RAM Mounts & More - Cruiser Design & Manufacturing (2 Viewers)
Are you able to make the dome and door lights compatible with Baja Designs dome and rock lights? Not sure the dome lights would fit in the overhead OEM plate, but the rock lights (I think) should work in the door.
Hey @samson100,
I have seen a few people make custom 3D printed covers that utilize our dome light for the OEM overhead light. Check out Rovrlab they might have a solution you are looking for!
Best,
Bill
Bill Sonevongxay | Forum Sales & Support 
Email: Bill@bajadesigns.com Phone: (760)560-2252
Been slacking on the 100 series a bit while trying to get some products out for the 80 series, I did just redesign my phone tray to fit inside the ashtray rather than out. After trying to find a nice way to run my carplay wire through the dash I finally decided to ditch the cigarette lighter and run a USB bulkhead there, meaning the old tray would be blocking it. This solution should keep me from pulling the dash apart again for the foreseeable future.
I'll be designing a flat or slightly tilted mount for the auxbeam panel to fit in the AHC spot that will work with this tray.
Hoping to finally sit down and make an underhood light mount for the hundo this month. My 80 series project is finally coming to an end and I just have to get the oil pan back on for it to be a running, driving, not-leaking-too-much machine.
Any thoughts on a rhd ram mount below the radio when the where the hazard switch would be. On rhd it's blank.
I think Bencc makes one.
Hello in regard to the cupholder. Do you need to order the xxl one to fit a 3.5" hydroflask? the large mentions the top step being 4" wide but is it deep enough to hold a tall 40oz hydroflask?
If it's anything like my large yeti bottles the top step will be deep enough to keep the bottle from going anywhere, but it will be able to tilt/rock around some.
Great idea! I’ve never thought of this as I don’t have rear passengers regularly and my rear cupholders still function fine.
A slip on/snap-in design shouldn’t be too bad to match the front set. I’ll add it to the list, thank you.
Did 2nd row cup holders get produced? Mine are broken, so a full replacement insert (perhaps like your taller front ones) would be nice. Thanks in advance!
Order Placed! Looking forward to adding this before my family road trip to Mammoth.
Do any larger cupholders exist for the third row dual cupholders, on the passenger side? When we sleep in the back, those holders come in handy but of course don't fit anything larger than a plastic water bottle
