Headlight switch bulb Mod
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Well my headlight switch bulb burned out again. And it got me thinking which is bad. So I took it out to replace it. As I had it out I thought to myself "I wish it was an led instead of a regular bulb. Thatway it would never need to be changed. So I did a little eletrical thinking and this is what I came up with.
I had some spare L.E.D. bulbs laying around. But most L.E.D. bulbs are low voltage 3 or 4 volts. And 12volts just blows them instantly. (trust me I know)
So I added a resistor and wha la a 12v led. The pics tell the story.
Note the resistor must be installed on the + terminal of the L.E.D.
I scraped out the old bulb out of the bayonet being carefull not to damage the black glass insulator on the bottom. Use a soldering iron with some compressed air to heat up the lead tip and then blow it away allowing for the +terminal of the resister to go through. Then you can solder, trim and file a little. All in all it took about 15 minutes to do.
Sorry about the blurryness but at night with low light the shutter on the camera has to be open for almost 15 secs. An eternity when hold it by hand.
thats sweet, looks like its 10x brighter than mine, ill send you my switch how much do you charge?
Great mod ! I am constantly amazed at the ingenuity displayed by IH8MUD'ers.....
Talk about ingenuity!! I love it!! Great idea!!
Trollhole is a master at mods!
HawkDriver said:
Now THAT is krafty. Real smoov man. I knew they were supposed to, but I don't think I've ever seen one that lights up. Extra LEDs around huh, what else have you created/modded with those little do dads?
I've got them running all around the railing on my center console boat and on the dash. I did do until I got the new cruiser a lot of night fishing. And I can run 20 of these on 3 aa batteries for almost 24 hrs. A lot better than the 2 headlights I had on a pole that sucked my accessory battery dry.
I plan on running the rest of the interior lights on these little babies. Heck I can just solder them into a 40 stock guage setup and be done with those pesky lights and turn signals.
yeah they light up but you need to put your face 2 inches away to see them, you the man troll
I did a very similar mod to the light in the dash above the switches. I used a LED kit from the ricer section of the local parts joint. They are designed for 12 volt, so don't need a resistor. They came in a string of 3 wired in series, all I had to do was drill the 3 holes in the lense, and they snapped in. Beyond that I used only 2 barrel splices. A note for those not familiar with LED's, they are Diodes, and will not work if hooked up backwards, thay are basically a one way "filter" for electrical current.
or you could buy this for 3 dollars.
Heh he they also have them in most colors even UV or Blacklight. I wonder how that would look.
I just bought L.E.D.s for every light on my cruiser including the new flasher. I'll post up my results when I install them friday.
hey troll will you send me some links were you got your lights, i would love to upgrade my dim old lights, dash and all. thanks man
i didn't even know that mine lit up... dammit...
Me neither, till one night the little bulb came out of it's socket and I thought there was a firefly trying to molest my knee!
I'm anxious to see the dash lights... is there a LED bulb for the dome light? I forget what bulb is in there.
