Side gear shims???? HELP!!!!
Dickinson, Texas
I'm re-doing my front locker & need some .170 side gear shims (Toyota pn: 41361-611410) & the local Toyota dealers can't seem to get them. (what's the word?....clueless!) Any idea's where I can order a set and not have to wait weeks for delivery?
Help!!
Thanks!!
Scott
call kurt at cruiseroutfitters
he'll take care of you.
x2. If he doesn't answer leave a message and/or send him an email. If he has what you need he'll get it to you. But, he gets more and more popular around here because he runs a great business. That makes him more and more busy so you may need a little patience. Worth the wait.
I e-mailed Kurt & he got right back with me. All he has are .150 washer/shims. SO the search is still on! (maybe the .150's will work???)
Scott
Thanks for the props guys... :cool:
Scott, I replied to your email... but I will answer here also for others in need. I have some aftermarket ones that are .150", but nothing larger... and I've used up all the thicker used OEM ones I had likely doing the same thing you are.. shimming a LockRight. Good luck, wish I had something for you!
Scott
Are you shimming a Lockright?? the .150's will leave you .040 off, could be too much. I'm sure someone has some thicker used stock ones kicking around??
Scott, I've got a small stack of them somewhere but I'm not sure what sizes they are. I'll double check.
Bring it to Katemcy and we'll install it in camp. :D
Jason,
The Roundup still hasn't made it onto the calendar. If you have shims it might!
Kurt,
Thanks for looking!
Scott
