Just around town
Camped there in 22, really cool area!
See any Condors? Hopefully you made it out to White Pocket.Vermillion Cliffs in the background at sunset.
wheel/tire setup on point - and all black so menacing
that needs a rear bumper badly to balance the lookNot mine but stumbled on this today. Good reference for '16+ LX with LC wheels and dissent front.
front setup looks the bestContinue to debate what I want to do with tires/wheels.
This shows a worn 285/75/17 on method mr314 next to 275/55/20 on black rhino 20”.
The body lines of the ‘16+ just work better with a 20” wheel I believe. May stick with the 20’s and just get more rubber.
+1front setup looks the best
+2front setup looks the best
I’ve debated this. Wish the mr314 came in an 18 with 30-40mm offset. Can’t have it all!Meet in the middle and go 18s?
Is it a rubbing or looks issue with the lower offset on those? Torn on 17 vs 18, wanting to run a 285-305 width and know what to expect on the 285, math just gets close on the 305sI’ve debated this. Wish the mr314 came in an 18 with 30-40mm offset. Can’t have it all!
Fronts just require the usual light persuasion?
Everyone is entitled to their own opinions. Even if they're bad ones.A vehicle as big as a 200-series just look silly on 18" wheels.
They would certainly rub but I’ve done all the “pre work” on the fender liners to reduce or eliminate it.Is it a rubbing or looks issue with the lower offset on those? Torn on 17 vs 18, wanting to run a 285-305 width and know what to expect on the 285, math just gets close on the 305s
