Looks like it would need to be ordered as separate parts.Is there a part number for the entire 08-15 lc200 roof rack, or would it need to be ordered piece by piece (ex. Cross bars, rubber gaskets, end caps, etc.)
Buy the Kats 11813. Perfect fit. They have them in stock at Napa locally here in Alaska but otherwise https://www.napaonline.com/en/p/KAT11813
Assuming your heritage has black interior trim, it should be 62605-60020-C0Hi Bloc,
Could you tell me the part number for the cover of the compartment where the jack is stored?
(On the passenger side of the cargo area)
For a 2021 LC 200, please.
Thanks!
You are correct. It’s black.Assuming your heritage has black interior trim, it should be 62605-60020-C0
For a 21 with beige interior replace the -C0 with -E1
Year? Yes they’ll all bolt on but we don’t know if there were changes to things like emissions system pressures and such over the years.gas cap assembly, or just the o-ring (if that’s an option). TIA!
Should be 53381-60110 for a '15 LCI'm looking for the number for the squishy rubber gasket/weatherstrip piece that sits on the plastic radiator cover, just behind the front edge of the hood. For some reason mine has expanded and no longer fits in the clips, I think it's the oil from my NHOU treatment still drooling out of the front of the hood. Tried to find it but I'm unsuccessful.
If you mean the guard bolted to the TC itself and kindof wraps around the bottom, 91673-80820Ok, I’ll play. When doing my TC fluid change I noticed I was missing one of the bolts for the larger shield. Does anyone have the part number for that bolt?
Also, I’d love to replace the transmission plate ‘check’ drain (hex plug) the next time I do a drain and fill. Any number for that?
These would be for a 2011 LC200.
TIA!
Sorry. It’s a 2021. TY!Year? Yes they’ll all bolt on but we don’t know if there were changes to things like emissions system pressures and such over the years.
No worries.Sorry. It’s a 2021. TY!
End piece with T: 09114-60090Here's one....the tool kit, or more specifically the end piece with the T on it to lower the spare tire from its carrier?
