- Thread starter
- #21
Figured out the cord situation today. Was concerned it would get caught up under the fridge when moving back and forth.
I took the standard ARB cord, wrapped it tight around a 1/4" metal rod, and heated it up with my heat gun until it was hot to the touch. Not so hot as to melt the cover but just the point it gets a slight shine on it. That causes it to lock in the "spring" coil so it somewhat retracts after being stretched.
Fastened one end to the top corner of the fridge and plugged the other into the power outlet. Stretches out nice and folds back up near the power outlet when retracted. Only downside is I won't be able to store anything on that side of the fridge now. I couldn't put much there anyway because it blocked off the vents on the fridge.
Another method would be to leave a gap (probably about an inch) between the frame and the cradle and use one of those wire chains to protect the cord. I didn't want the extra height though so this method works for me.
