Oh, and some trout fishing in the lower Sierra..wild native rainbows..catch and release for another day..
If it happens to be your differential switch remember that the reverse light switch is the same thing and cost less. It's happened to mine too where the center diff light wouldn't light up and thusly not allow me to lock front and rears. I just used the reverse light switch in the center diff and it was all good after that. Something like this:Spent a nice little solo weekend at Windrock doing some site seeing, overlooks, and easy trails. Discovered my CDL is failing to actuate so I'll have deal with that before GSMTR. Found a lot of threads on the topic and will be doing some investigation this week. I checked the 30a fuse and can hear the relay click but no sound from the actuator itself. Worked fine a couple of weeks ago.
Windrock fields
Two power stations at blue hour
Posing at the old radar base
Posing at Clinchmore
I’m afraid to look. I’m like 12mpg on average. Off-road is a different story. I estimate 10mpg as a decent cushion for range…Updated fuel log.
16.229 mpg over the last 6300 miles and 23 full ups.
Best 20.165 worst 14.785
That looks like way too much work. Seriously, buy a fuel jiggler siphon and leave the can in the basket.I finally figured out an easy way to refill from a Jerry Can while out in the Maze District......what took me so long to figure this out?!?
(My can is dented making this totally hands-free, my normal can I had to stand by and watch for slippage but still didn't have to bear any weight!)
Don't forget, his is a diesel.I’m afraid to look. I’m like 12mpg on average. Off-road is a different story. I estimate 10mpg as a decent cushion for range…
My 1FZ averages 11.5 over the last 5 years.
A siphon tube works well and you don't have to take it out of the bumper swing out.I finally figured out an easy way to refill from a Jerry Can while out in the Maze District......what took me so long to figure this out?!?
Nice work! What paint and brush type did you use on the emblems?Finished up my caps. Turned out pretty nice. Need to clear them yet. The gold emblem takes some patience! @cruiserdan was right on with the Duplicolor Silver suggestion.
View attachment 2985886View attachment 2985845View attachment 2985846
Maybe do a write up on this? I’m sure others, including myself, would like to follow suit.Finished up my caps. Turned out pretty nice. Need to clear them yet. The gold emblem takes some patience! @cruiserdan was right on with the Duplicolor Silver suggestion.
