Two most common - water or rodents. Windshield replaced or been raining a lot lately? Checked your air cleaner for a nest?
Windshield seal. Spray something foamy on the outside along the edge, shoot compressed air from the inside. If you see bubbles, you've found your leak. Could also be sunroof drains, but you'd probably see that on the headliner. Search on checking and clearing those.
Alright, thanks.ECU, kick panel fuse block, etc. There's plenty of electrics it can get to inside the cab.
