Hey guys - so Im finally ready to start a bit of a refresh on the 40 -
I am on a pretty tight budget but what i would like to achieve is:
-rust on chassis gone (not major rust yet but all the paint is gone so its covered in surface rust - will probably get it blasted)
-rust in the body cut out new bits welded in
-new paint -033 White as it was from factory (current paint is like chalk)
-all new rubbers/weatherstrip - probably from ccot as i cant find anywhere cheap in aus - only problem is the front windows as mine has 1/4 glass and ccot dosent seem to have window rubber for them
-sound deadening/heat sheild, most likely dynamat in it various forms i am taking the black tar stuff off - cant stand the stuff its all melting into the grooves in the floor and leaving the ridges exposed
-engine swap:
I am going to swap out the 2f (works fine but i want a more modern engine) with a Toyota 1UZ-FE v8 mated to the H55f transmission with a dellow conversion kit.
So yeah
Ill try and document it as I go.
all comments and suggestions welcome
a lot of you have far more experience than me
Here are the Pics So far
As it was when i started
Some of the rust to repair
dunno how im going to fix this
After day one of the teardown
Pulling the engine - Ill miss the ol 2f :\
3rd day pulled loom, wheel and dash stuff
Damn Tar stuff
-engine swap:
So yeah
Damn Tar stuff
