I have read lots of articles on 4 wheel disc brake mods, plus the tech section. It seems that when doing 4 wheel disk brake mods there is no consensus on the best master/booster to use.
I have a '71 40 and am building up axles from a '76 to go in. So I have front discs now and plan to mod it with slotted rotors from a V6 along with the calipers (I think that was the preferred mod). I have brackets for the rear using Monte Carlo calipers. I am also putting in a Chevy 305. I will be using 36" or 37" tires.
So I need to use a brake master that will handle the increased fluid requirements, has the correct residual valves, etc. but which one?
What master/booster (from what model/year vehicle) would be the best fit and easiest to add? I have decent fab skills and tools, so cut/grind/weld is no problem to make it all fit.
What do you all think?
Steve
Steve
