York 210 + AC on 1HD-T
Kamloops, BC
Website
www.forgottenbc.ca
Inspired by @themorb 's work, I set about to do the same... shoe-horn a York 210 AC compressor as a kick-ass on board air setup and RETAIN my air conditioning. Living in Kamloops summers with 3 little kidlets I definitely need to keep the AC. Here, AC > OBA.
I followed the same blueprints as Nathaniel (ok, I printed a bunch of his pictures and eyeballed it, then proceeded to ask 1,000,000 questions). I made only a few changes, such as using countersunk bolts to hold the 1st section bracket to the York, and utilizing the 1HD-T Denso top plate (Nathaniel used a FJZ80 one).
A friend down the road from me runs a CNC table, so this definitely helped. I then sandwiched the York between the relocated Denso AC compressor and the engine, re-located some of the electrical from the right side battery box, re-ran the alternator cable and Denso clutch wire, and strapped a longer Napa V-belt over both pullies. The OEM idler (tensioner) was moved to the custom bracket and used to tighten the belt.
I ran electrical (Switch on dash --> fuse + relay in custom Toyota additional fuse/relay box --> pressure switch) and included a line to the VSV idle up circuit with a couple diodes, so the activation of the York clutch would automatically idle the truck up.
I ran 3/8 air line to an air block I mounted on the firewall in the engine bay, which held the pressure switch, an extra Milton quick connect with adjustable pressure for air tools, a high-flow safety release valve, and a gauge... then from there down along the left side frame rail (encased in 3/4 split loom) to the back of the cargo area to a 200 PSI Viair hot dog air tank and Milton air/water/oil separator. From there back along the same frame rail run to the front bumper where I mounted a Milton quick connect.
The york is snorkel-fed clean air via a JIC bulkhead fitting in the middle/bottom of the truck's airbox.
For the Denso AC top plate, I had to get the low side fill shraeder valve cut and welded closed (aluminium) and an AC shop to install a new in-line fill port in the low side hose near the turbo. The high side line fit with a small tweak of the hardline. The high side fill port is accessible beside the airbox.
Initial air-up tests were impressive to say the least. At idle (up) ~1,100 it took about 45 seconds to fill a 33 from 16psi-40. Then using my hand throttle, at 2,000 rpm it took 23 seconds :O
Bought 3 belts, returned the 2 that didn't fit :)
I should! There was a bit of monkeying around with bending the lower section that supports the Denso and some fiddly bits, but I think the main portions (that were cut with the plasma) would be usable.
Thanks!
In retrospect, I think the only thing we had on the computer was the (1st) bracket that holds the york to the engine. The other one, between the York and Denso, was just plate steel that we milled out and bent. I'll see what I can find...
Also, thx guys :)
Still waiting for my royalty cheque :p Looks good, a few improvements on mine. Notably, the ability to re-use the hose that goes to the condenser........ not sure why I made that way more complicated than it had to be :bang:
An update on the project. I had the AC shop make me a new hose with the charge port in the middle of it (as the low side charge port was in the way of the York and had to be cut/welded closed). This allows me to properly charge the AC system yet. I haven't charged it yet though as it's too cold out to properly do it, and I'm still working out a few small bugs.
They were not able to salvage my old low side hose, so they made me a net new one using the hard lines from either side. They used R134 hosing which is stiffer than the old R12 stuff. Now I have a small harmonic vibration at various RPMs (1,000-1,200, 1,800-1,900, etc) that I can feel in my brake, fuel pedal, and dash.
I've re-attached the dampener foam on the hose (from the old hose) and secured it to the spot right before the firewall that they do from factory, which helped a bit. What other ways can I reduce the vibration transfer up the stiffer hose?
Anyway of acquiring some of your pictures because they’re no longer available on this thread and I really need a York 210!
My version York OBA install
Yes, I still have them. I'll try and post them tonight for you! Looks similar to @Obrokoff 👍
@Obrokoff Looks great! Do you have those cad files, and are you willing to share? Looks way better than what I could cobble out of cardboard templates.
Someday Ill find the time to do this.
I was wondering if there are CAD files floating around?
I need to fix drawings. Couple mistakes in it.
