Admission: I'm a total novice with automotive electronics. I could use some help from someone who knows more than me.
I have a '97 FZJ80, with the OEM headlight wiring harness. I had upgraded to 9011 / 9012 bulbs about one year ago, and just recently noticed one of the low beam bulbs was out, then a few days later, the other one. So, I was a good MUD member and searched, searched, searched for other folks with similar problems. I think I read 15 different threads and still can't find an answer - evidently the 9012 bulbs draw more current so may melt relays or blow fuses, but I can't find any evidence of that in my truck.
To date:
- corner lights work when switching the light stalk to low beam setting; low beams themselves do not.
- high beams DO work, including when just pulling back on the stalk, as if to flash / dip one's high beams
- checked the headlight relay on the driver's side in the panel in the engine bay, it seems in good order
- checked the right / left headlight fuses in the panel in the engine bay; they're fine too
- removed both 9012 bulbs - the filament had broken on one of them, but the other is just fine
- as a test, replaced both 9012 bulbs with the good, old 9006 bulbs I removed a year ago ... but they don't work either.
Anybody with a bright idea? Help me Obi-Mud Kenobi... y'all my only hope!
To date:
