- Thread starter
- #61
OK, here's a little update...
It's been a week since I installed the Camry modulator and she has yet to throw a code
Anyhoo, here's the testing procedure I went by (AllData)
EGR VACUUM MODULATOR INSPECTION
1) Disconnect vacuum hoses from EGR vacuum modulator.
Disconnect these vacuum hoses:
(1) Vacuum hose from R port
(2) Vacuum hose from Q port
(3) Vacuum hose from P port
2. Inspect EGR vacuum modulator operation.
(a) Block ports P and R with your finger.
(b) blow air into port Q and check that the air passes through to the air filter side freely.
(c) Start the engine and maintain speed at 2,500 rpm.
(d) Repeat the above test. Check that there is a strong resistance to air flow. If operation is not as specified, replace the EGR vacuum modulator.
3. Reconnect vacuum hoses to EGR vacuum modulator.
Connect these vacuum hoses:
(1) Vacuum hose to R port
(2) Vacuum hose to Q port
(3) Vacuum hose to P port
With that said, I'd like to add that removing the modulator altogether and testing vacuum on the bottom port to see if the diaphragm had any leaks was more straight forward in my case and should probably be added to the testing procedure
