(Work in progress) - So you want to swap a H55F 5-Speed transmission into your 40, 60, or 62? (3 Viewers)
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
(Work in progress, tossing this out as I have some time in an Uber this morning :D)
So you want to swap a H55F 5-Speed transmission into your 4x or 6x Series?
Why? Well, 5th gear and a lower 1st gear. New smooth transmission and the split t-case. The H55F features a 15.5% overdrive (0.845:1 in 5th gear) versus the 1:1 of the J30 (3spd manual) & H41/H42 (4spd manual). It also features a much deeper 1st gear than most Cruiser manual transmission options for better get up and go as well as control and finesse offroad.
(future trans ratio chart coming)
h55fcombo_2__13952-png.3196955
We offer fully assembled and customized H55F/Split T-case combos here:
Those combo's include the H55F (several options available), the transfer case (several options available), and can include the necessary 5-speed specific shift lever, knob, hardware, flanges, etc. In addition, you will need these items for your year/model:
Early FJ40 w original J30 3-Speed Transmission & 1-Pc T-Case
Bellhousing (requires a 4/5 speed Bellhousing)
Factory frame cross-member mods
Custom cross-member to support H55F
Floor/Trans Cover mods
Transfer Case Shift linkage (Part# TCSCSHFTKIT avail @ CruiserTeq.com)
Transfer Case Floor Boot
Driveline length mods
Speedo cable replacement or extension (new cable preferred)
Park Brake mod*
75-80 FJ40 with original H41/H42 4-Speed Transmission & 1-Pc T-Case
Park Brake mod*
xx/80-xx/1985 FJ40 (originally equipped with Split T-Case)
Slight modification to stock trans cross-member for front driveline clearance.
Frame cross-member relocation (if retaining/using t-case mounted park brake)
*8/1982-10/1982 34mm transfer cases have a unique input gear/seal arrangement and lack oiler cup provisions. Using a 10/1982+ or new t-case is recommended
8/1980-xx/1985 FJ60 with H42 "Short" Transmission
Driveline length mods (shorten rear shaft & lengthen front shaft)
*08/1980-10/1982 34mm transfer cases have a unique input gear/seal arrangement and lack oiler cup provisions. Using a 10/1982+ or new t-case is recommended
xx/1985-xx/1987 FJ60 with H42 "Long" Transmission
Direct Fit!
1988-1990 FJ62 originally equipped with A440F Automatic Transmission
Bellhousing (requires a 4/5 Speed Bellhousing)
Flywheel
Clutch Assembly (CL7487KIT)
Cross-member mods
Transfer Case Floor Boot (option to switch to manual shift 2WD-4WD shift linkage)
Clutch Pedal Addition
Clutch Master, Slave, Hard Line & Hose
Minor wiring modifications
Short vs Long H42
The original H41/H42 "short" was replaced with the "long" variant in xx/1985. As with all things, there can be overlap so it is always best to inspect what you have. The long variant is very easy to identify by the presence of a 'spacer' between the back of the transmission and the transfer case itself. This housing is where the 5th gear setup resides in the H55F. In order to maintain parts compatibility in later Land Cruisers, Toyota added the spacer to the 4spd to match the length of the H55F 5-speed. This allowed items such as drivelines, wiring harnesses, etc to be universal regardless of the 4 or 5 speed trim.
Bellhousing & Crossmember Variants
Toyota utilized several different 4/5spd bellhousings and they are not all equal. The early 40 Series 4spd bellhousing will have rear motor mounts on the side, this can be extremely useful for mocking up the setup in an FJ40 as the mounts will work for the 3 or 4 speed frame. The late FJ4x and all FJ6x bellhousing will not have these additional mounts. The 80+ bellhousings come in several varieties, clocking of the transmission as it releates to the engine changes and the crossmember will need to match the bellhousing you source. Options/pairs include 8/1980-10/1984, 11/1984-07/1987 and non-US variants.
Park Brake Solutions (applicable to the 40 & 55 Series)
The standard H55F/Split-Case combo does not have a t-case mounted parts brake as found on the original. There are a handful of options:
1. Move the park brake to the axle. This can be done by using later model or modified rear axle equipped with the park brake or adding a disc brake conversion with the park brake feature. This will require a custom park brake cable.
2. Convert the back of the split t-case to a factory park brake drum setup found on the 4x/6x in non-US applications. This will also require a longer custom park brake cable. This requires a new T-Case rear output shaft (Part# TCSHFT3623160031), a Split T-case specific 19-Spline park brake drum (Part# PB60030) and a drum brake specific Split T-Case rear output bearing retainer (not currently available new - Email for availability). You will then use your existing t-case mounted park brake backing plate, hardware and shoes (all from a 1-Pc case). This will require a custom park brake cable application.
3. Convert the back of the split t-case to an aftermarket disc park brake setup sourced from Colorado based TSM. This will require custom park brake cable modifications.
Which Split-Case will work?
There are 50+ split transfer case variants used by Toyota. Major changes include low range ratio and vacuum 2WD-4WD shift versus manual 2WD-4WD shift. It's important to note that not all BF1 cases are setup to run behind a 5 speed due to their lack of provisions to add the 5th gear oiler. This small plastic device collects oil as it splashes around and funnels it into the back of the transmission assembly.
( Setting up the H55F in my 1972 FJ40, circa 2002. Same transmission has never skipped a beat :cool: )
Sorry, this looks like an old maybe dead thread. Thanks for the info.
Is there any advantage to going with a 7x transmission support to an early 4x? Pulled a h55f out of a 60 and putting it in a 40, somehow didn’t keep the transmission support. Do you all have options available?
Not dead at all, still getting updated.
Are you referring to the crosss-member under the transmission?
I'm in same boat, can't find the crossmember I had previously purchased to put in my BJ45 when i swap the H55, Kurt is this something you sell? If you do I am sure it's nicer than what I have.
Not at current. There was an aftermarket option out there and of course many used options from 4x/6x/7x variants.
@cruiseroutfit i have an ‘87 FJ60 with a stock 2F/H42F and I’d like to do a H55F conversion. According to your post it should be a direct swap but is there anything else I’ll need? Or is there a write up with those little pesky details?
Thanks
Thanks
Direct fit!
You need the transmission (TR60450), oiler (TR36010), the 5spd shifter (TR60160) and a knob (INT14050) to show off that extra gear you now have. All parts we have and can ship as soon as today from Cruiser Outfitters.
There are a couple of other small items we send out complimentary, just mention the job you’re doing when you order and they’ll include them.
Now, it’s also a very appropriate time to reseal and/or rebuild your t-case and at a minimum for you’ll want a gasket kit and a few stake nuts.
Gaskets only:
Rebuild kit:
Direct fit!
Gaskets only:
Rebuild kit:
Hey there, I see you are actively responding to this thread. I posted this yesterday and maybe you can help me resolve some of my concerns.
I wanted to do a simple engine swap but have since started to rethink it.
Thanks in advance
Thanks in advance
Sorry, quick glance at your thread I'm not seeing a question on H55F combo's. Post your H55f/T-case question here please.
I have the early variant of the FJ60 H24F four speed, without the spacer. Can I use my existing shift linkages in the swap to the 5 speed if I keep (rebuild) my existing transfer case? Just want to make sure I get my order correct before I press submit.
They would require modification to utilize as the transmission length impacts the linkage lengths. I've posted pics of each here on Mud, let me see if we can find them. We do stock several options, the AA Twin Stick and the TT Stock Repro kit
Can the 4-speed skid plate be adapted to the 5-speed?
If the H55F is set up for a FJ60 the shift tower is on the back of the cover.
You can cut an oval out of the top of the transmission cover on the floor and turn it 180 and weld back in.
Find a FJ40 shift cover with the tower at the front end like the 4 speed and Georg maybe able to help with that.
I got a section of the floor cover for a FJ60 and will graft it into my 78 FJ40 which should take care of the H55F shifter and the transfer case shifter.
The transfer case linkage is also moved back 3" and the lever will not be in the same hole as the 3 speed transfer case shifter hole.
So you can modify the floor cover for the TC or switch to a twin stick.
Is a body lift or floor mods required if swapping into a earlier (1969) fj40?
Yes, the floor/trans cover must be modified for clearance and shifter locations.
The torque tube is also to close with the parking brake because the rear drive is 3" farther back. The drive shafts will need to be replaced or modified for the 3" offset to the rear.
And don't forget parking brake, drive shafts, flanges
Those are in the list of necessary mods in post# 1
So I have a 1979. Considering the 5 speed upgrade. If the 5 speed is providing a lower 1st gear, would I still want to drop gearing in the tcase or would the 5 speed lower 1st do enough for most folks? Current gearing is a little too fast in 4low 1st in some situations when you just want to crawl.
Any recommendation on where to have a custom brake cable made? Which is your preferred ebrake solution?
  • Back
