- Joined
- Oct 25, 2008
- Threads
- 40
- Messages
- 1,331
- Location
- Central Oregon
- Website
- www.oregoncruisers.com
Was" wont idle and amp meter is pegging" now who knows LOL
Hey all! Took my stock 69 for a lil drive today. On the way back I decided to test out my new brakes. Slammed em on and they work great! But my motor died.
Started it back up and it would not idle and the amp meter would peg the + side with any rpms.
Motor sounds and runs fine as long as I keep the rpms up.
Stalled it again. Then I started it up and it was fine till I got home then died again as I pulled in the drive.
Brought it in the shop and messed with stuff for a while.
Tried to start again and it ran fine, idled, and the amp meter was acting normal. Shut it off, cleaned up some tools. Went to take it for a spin to see if I had actually somehow fixed the problem. Started acting up again. Same deal wont idle, and the amp meter is either pegged when some throttle is applied or drops to the negatives when you let off the gas. Motor dies if you let off completely.
My neighbor and I think its the regulator but thought I would run my symptoms by the pros.
I though maybe something was shorting out....would sort of explain the problem starting after my
'brake test".
But having the problem go away and come back just sitting there in the shop leads me other directions.
What ya thinking before I start ordering parts?????
'brake test".
