Wits End Turbo Owners (4 Viewers)
Status
Not open for further replies.
I have one large exhaust leak at the flange where the J pipe connects to the factory downpipe, but that shouldn't trip a lean code, I'd think.
that's exactly what would cause a lean error. You are drawing in air which the O2 sensor will see as un-burned oxygen and attempts to correct this by adding more fuel, which will have no effect, and eventually triggers a P0171, system too lean.
Ok, that's very interesting as I didn't think negative pressure existed in that part of the exhaust system. I'll need to remove the turbo and try to fix this issue. Thanks Rick.
I've been getting a lean code as well but that's been happening pre turbo so there's still a leak somewhere in my system. Using a smoke machine, i was able to find lots of small leaks and one large leak
Smoke machine bought on amazon? Tempted to see if I should buy one or borrow one from someone locally.
I have officially preordered the Wits End turbo, is there a badge or even a jacket I get now that I am a part of the club?
Something like this, because if Burt wouldn’t approve neither will I.
Wait, I got panties withnmy turbo kit and I thought they were Joey's....
Finally got around to checking how much junk my oil catch can system is capturing after ~1200 miles on 184K motor, all original
Valve Cover and Air Intake Catch Can // ~4 oz of oily, foamy slurry
Valve Cover - Intake Manifold Catch can (PCV-side) // ~1.5 oz of darker fluid crap
Hey I'm south bay as well and am a couple weeks away from doing a pressurized leak test. I've already used the standard smoker but I'm guessing my 'lean under low boost' problem resulting in pings is caused by a leak I need pressure to find.
I'm local. ping me too and the 3 of us can coordinate on a date/time/loc
Anyone else watching the white, turbo 80 on Bring A Trailer?
Status
