Alright, this thread has prompted me to want to fix my leak--- so I think I am going to order some 3M 08509 windscreen sealer/bedding compound off ebay and give it a go. That does seem to be consensus over the 3M 08609 urethane, right?
At least based on the description in the UK catalog and the 3M data sheet that ehouli found, that seems to be the most logical choice of what is available.
Yes you want butyl (or butyl like) NOT urethane.
Yes, but only the regular Sikaflex 256 is available.The Sikaflex 256HV that is in the FSM is polyurethane isn't it?
Ok thanks, I'll be getting a professional to do the job since then if I need to get the windscreen frame/opening repaired prior to new glass going in I'll book it into a local body shop.
Make sure they understand to use the sealant. Several experiences on here of techs being told and STILL not using it.Ok thanks, I'll be getting a professional to do the job since then if I need to get the windscreen frame/opening repaired prior to new glass going in I'll book it into a local body shop.
I just replaced my leaking windshield on my 93. by ordering a new gasket and taking to an auto glass shop. Not a drop of water and its pouring outside.It looks like I will need a new windshield for my 93 80. This is being paid for by my insurance, so they want me to use one of those mobile replacement companies. I am a little leary of those guys, so I am going to watch them carefully. At least they claim to use OEM parts.
So two questions, should I insist that they replace the windshield gasket at the same time? I think my current gasket is original, so it is 13 years old. What is the part number for that gasket? (so I can check up on them).
And what is the correct sealant they are supposed to use?
Anything else to watch out for?
Jared
PS-- called my local toyota dealer, and they don't replace windshields
Did you ever resolve the sealing problem to your satisfaction?No problem, thanks for clarifying this point, as I thought it was a bad translation somewhere.
I did find the Third product shown on the SST on the net. Comes in a box with a two little bottles, one of them is Primer and other couldn't find what it is, applicators for the primer and a piece of wire, not cheap, in ebay goes up to almost $60.
Also found the datasheet for the 3M Auto Bedding and Glazing product which goes along the instructions for Windshield installation given by Toyota.
forum.ih8mud.com
