So my truck is still up on those stands...
- waterproofed the distributor cap so I don't die the next time I get swamped.
- flushed the power steering fluid, which was BLACK
- removed, cleaned, and regreased the front and rear driveshafts
- inspected and found a leaking speedo gear
- tightened and generally inspected everything underneath (found a few loose bolts)
- replaced the PS front rear control arm bolt with OEM, which was rigged up at GSMTR when it fell out.
- replaced the DS front front control arm bolt with OEM, which was removed to rig up the replacement of the previously mentioned missing rear bolt
- tore down front DS knuckle, cleaned everything, replaced all races and axle seal, waiting on knuckle studs to arrive before I reassemble.
TO DO:
- assemble DS knuckle
- tear down and clean PS knuckle, reassemble
- clean the inside (I found a month old starbucks cup in there...niiiiiice smell!)
- clean the outside (I pressure washed, but want to tire wet it before OTMT.
- oh, and fix the pressure washer that I broke...whoops
