- Joined
- Jul 22, 2012
- Threads
- 583
- Messages
- 16,418
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
It works fine. You need to set your welder at +DC.
wrapping the exhaust will just be a moisture and dirt trap for an offroad rig. I doubt the exhaust is going to build any significant heat anyway being 3'' in diameter and especially if you decide to run no muffler. my 61 sounds amazing with no muffler. Since you are making fuel lines and such I agree would be easy enough to redo your brake lines and run them on the driver side since the master is on that side anyway.
Disagree. The exhaust will be 1000* or more coming out of the turbo (depending on his tune). Dirt isn't an issue and moisture will burn off really quick.
Muffler is up to personal preference, but wrap is a good idea.
the exhaust will be that hot directly after the turbo not the exhaust pipe. Even with extended drives pulling long hills the pipe will not get anywhere near 1k degrees.
