RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
he has these for ALL lifts, send him your measurements and they show up in mail. Just installed these yesterdayNice! Are these only for certain lift heights? Would it work with a 2-2.5 inch lift?
I had the same issue with my Blackhawk HD swaybar. I needed to grind the corner for it to fit the link.I purchased a BTR46X for my 80 and purchased slightly longer links from Cruiser Outfitters (only about 1in longer). Since I only have a 2in lift I guessed that these would be long enough but I was wrong. See pics below. This brings up two questions that I hope someone can answer...
Thanks in advance!
- What set of end links can I use that will be long enough for my lift BUT not too long to were they'll be hanging below the lower control arms and catching on things? I'm considering the MAF ones but want to try and make sure they'll work before ordering. (Yes, I saw the adjustable LCP ones which are super nice but simply overkill for my needs and budget).
- Regardless of what end links I get will I still have to grind the corners off of the sway bar so that it'll fit the end links?
Gotcha, I was trying to avoid that but you're the second person to say the same thing. On the bright side I think that if I grind off the corners then I'll be able to use these end links instead of having to order new ones.I had the same issue with my Blackhawk HD swaybar. I needed to grind the corner for it to fit the link.
yeah, I think you'd see the same issue with any other end links. I have several style links that I was able to compare when I did mine and they all would have fit the same.Gotcha, I was trying to avoid that but you're the second person to say the same thing. On the bright side I think that if I grind off the corners then I'll be able to use these end links instead of having to order new ones.
This is exactly what I was trying to figure out, thank you! Based on all the pictures that I've seen the bolt hole location is almost the same on all the end links. I figured this would mean that they would all still collide with the sway bar regardless of the overall length of the end link.yeah, I think you'd see the same issue with any other end links. I have several style links that I was able to compare when I did mine and they all would have fit the same.
Before I got my LCP end links I was using a set of OEM links and I cut off and welded on some new "horseshoes" to the end of the links that were longer and would clear. There's an immense about of force that is on those links at times so if you had longer horseshoe ends they'd need to be really beefy so they won't bend. In the end it's much easier to just grind the swaybar and it doesn't hurt anything.This is exactly what I was trying to figure out, thank you! Based on all the pictures that I've seen the bolt hole location is almost the same on all the end links. I figured this would mean that they would all still collide with the sway bar regardless of the overall length of the end link.
That makes sense. I wonder why Whiteline/other manufacturers don't round the corners themselves? It seems like they should've realized/corrected this issue by now.Before I got my LCP end links I was using a set of OEM links and I cut off and welded on some new "horseshoes" to the end of the links that were longer and would clear. There's an immense about of force that is on those links at times so if you had longer horseshoe ends they'd need to be really beefy so they won't bend. In the end it's much easier to just grind the swaybar and it doesn't hurt anything.
what types of improvements or defects are you seeing on road? definitely considering purchasing.WHITELINE BTF66X
I think i bought mine off of Amazon....Rear only, might need to get this front to match, but mine drives pretty good with the OEM up there still.
