All good in the 'hood bro, thanks for the update.
Hey Phil, what suspension are you running on that 80?
Also, I really like my Whiteline rear sway bar. Much more controlled heading over highway 17 to Santa Cruz than before. Gonna throw my RTT back on soon and I'm sure it will help with the top heavy wallowing I was getting before.
I can now report from testing you can get 100% articulation of your rear suspension with a WhiteLine rear swaybar attached. I did optimize the swaybar set up with a properly sized swaybar links. I love this product.
Do you have those links up on your website? I need a set for 2.5/3 inch lift.
No because to be accurate/ideal they need to be built per each vehicles lift.![]()
Make it adjustable??? A fatter tube with a big grade 8 bolt with double nut locking? If require cutting then there are Plenty of options out there already.
Interesting, I had no idea our rigs even had a rear swaybar.....i wonder if the japanese hdj81's just never came with them, or if mine was removed? would be a good upgrade....
I'm assuming you got the land tank ones from wits end?I can now report from testing you can get 100% articulation of your rear suspension with a WhiteLine rear swaybar attached. I did optimize the swaybar set up with a properly sized swaybar links. I love this product.
No I needed/wanted something stronger and adjustable.
Severe Duty Rear Sway Bar Links - Land Cruiser Products - LCP
Land Cruiser Products Land Cruiser Partssites.google.com
