Where to "300,000 Mi" It
I would drive it to the Toyota 50th anniversary on October 31st in Torrence, CA.
Roll in and hit 300K.
That would be cool.
-o-
I'd like to know the history and repairs done on your truck also...congrats!
I need to update but here is a start.
More are ROTW https://forum.ih8mud.com/showthread.php?t=48277
1994 Toyota FZJ80
207788 5/4/2002 New
208067 5/4 oil Hav10/30,
Toyfuel inj cleaner
trany oil
t-case oil Mobil1
fuel filter
208625 5/17 Bosch plug wires
NGK spark plugs
210000 7 to 10 center diff lock switch
new t-case
rear main seal
Newfields CV axles (both)
front diff bearings
steering knuckle bearings
newnwheel bearings front
rotor cap
tires Wild Country RVT 285/75/16
brake rotors, all 4
parking brake part ???
Syntech brake fluid
u-joints all
tie rod ends all
nuts, bolts for drive shaft
caliper rebuild rear
bleader valve rt rear
wheel flanges front
speedo gear (correction for big tires)
210710 10/30 thermostat
water pump
front engine seal
coolant Dexcool
front diff seal
ARB Bull Bars (front bumper)
210951 11/14 oil Mobil 1 10w30
213855 12/30 oil filter only
214440 ?/2003 front end alingnment
215119 2/3 sea foam in gas tank
217088 add 1 qt oil (pan leak)
217236 3/11/2003 PCV
oil filter
217453 3/14 check engine light code 71 EGR
sea foam in PCV
sea foam in oil
rotate tires
220088 4/28/2003 oil pump cover seal
220230 4/29/2003 oil Mobil1 10w30
220515 5/3/2003 clean intake chamber, EGR port pluged
EGR gasket
intake chamber gasket
valve cover gasket
MAF gasket
spark plug guide seals
OEM plug wires
valve clearance checked
221591 5/21/2003 t-case leaking
t-case oil Mobil1 75/90
diff oil 80/90 Amsoil (both)
222464 5/25/2003 add 1qt oil
222652 5/31/2003 front diff companion flange & pinion seal
222667 6/4/2003 new t-case, replaced under warr. as it leaked.
front diff seal(MAF)
223377 6/16/2003 TRD airfilter
224319 7/6/2003 left side tires rotate
224584 7/13/2003 oil change RotellaT 15w40,
VSV for EGR
add 1/2 oz Counteract to FR LF tire
seal outside of oil pan, the front part of it
225010 7/20/2003 clean EGR modulator and temp sensor
225650 8/1/2003 Check Engine light came on and off, clean modulator
paint receiver POR15
226085 8/12/2003 new EGR modulator,
rotate tires,add 1/3 qt oil
new rear wheel bearings
mount spare tire used 285/75/16
new SS bolts on cat skid plate
ass 1/3 qt oil
226660 8/18/2003 Slee Sliders w/running board,t-case skid plate,
add 1 qt oil
227419 8/20/2003 p/s line leak return line from gearbox
227455 8/21/2003 Napa 5/8 hose (too tight but worked)
227582 8/22/2003 1 qt oil
227736 8/22/2003 BG44K to gas
229060 8/29/2003 drain coolant remove radiator replace drain plug,
5/8 Gates hose works for return hose P/S injector clamps for clamps
new set bolt for alt.belt
229197 8/31/2003 replace front diff pinion seal OEM and used FIPG(transaxle sealant) on lip of seal
229298 9/1/2003 oil change 0w40 M1
230854 9/30/2003 Dexcool new radiator hoses
231632 10/14 set timing 3 deg
231750 10/14/2003 add 2/3 qt oil
232098 10/26/2003 oil change 10w30 Chevron
232846 11/25/2003 rotate tires, add 1/2oz to the one tire that was short Counteract
232855 11/27/2003 Lucas injector cleaner in gas
233600 12/17/2003 1qt oil, oil pan slow leak, new seeping leak at timing chain cover (now 2 seeping leaks)
234941 1/9/2004 add 1/2qt oil
235329 1/16 BG44K to gas
325704 1/20/2004 oil change RotellaT syn 5W40, oil leaks stoped some time after that
238263 3/26/2004 add 1/2 qt oil
238600 4/1 add 1/2 qt oil
239166 4/11/2004 add 1/2 qt oil
240146 4/26/2004 add 1qt oil
241285 5/13/2004 O2 sensor, cat&front ppe gaskets
241549 5/22/2004 fuel pump
a/c belt tensioner pulley
P.side door stop
oil pump regulator & spring
oil filter add 1 qt (1/4 low)
241997 6/6/2004 Seafoam to gas & oil
242492 6/20/2004 oil change RotellaT syn 5w40
244617 7/30/2004 Toy FI cleaner in gas,
245383 8/11/2004 change coolant ToyRed
245490 8/14/2004 add 1/2 qt oil
new/used front suspension springs OEM (date and mi I did the change ???)
246058 8/28/2004 add 3/4 qt oil
247805 9/18/2004 add 1 qt oil
248644 10/16/2004 unplug port "R"
clean & oil TRD airfilter
249185 10/31 add 1 qt oil
249312 11/3/2004 New front shocks
new P. side front wheel bearings
249680 11/12/2004 ProComp XTerraina 285/75/16 4oz Equal,alingment,
249800 11/16/2004 front R. tire shakes steering wheel, put it in rear no shake,remove tire and spin balance still shake,
250243 12/4/2004 add 1 qt oil
There is more, I just need to update
Some guy drove his '97 Chevy truck a million miles on a K&N airfilter.
That's a lot back and forth, those things are only about a foot long after you drive over them once...:D
That would be cool.
-o-
Seriously, though, that would be cool.
That's an impressively detailed maintenance record.
Looks like your most serious issue has been the t-case.
What kind of failure did it have?
The t-case was my fault.
I greased the rear yoke without knowing that the yoke was plugged with old grease.
The over greasing turned the driveahsft into a hydraulic ax. That action would make the t-case over heat and lock up the viscous coupler making me think the t-case was toast.
After I replaced the t-case, I found the yoke to be plugged:mad:
After inspection of the t-case I found nothing wrong with it.
So I spent $2000 for nothing.
Short story: I ordered a t-case, it got damaged by UPS, the replacement t-case started leaking within a year to Toyota gave me a replacement at no charge.
Other than the t-case (and gas), it has been a cheap vehicle to own.
Ship it to NC and go on a Cullowhee expedition trip with us and get rocked on moonshine :)
I think you should get your wife to help you with it. Then you can start the 300,000 mile club :D
DING DING!!! We have a winner! Good one Romer!
