What tie rod for 40 axle with large pattern knuckles?
Huntsville AL or Yuma AZ
I realize alot of people use shims and the 40 rod but I want to use 60 series joints for the added strength since I also have a 60 steering box. If I remember correctly many years ago I read there is a factory tie rod that can be used with this application. Cant seem to find the thread. Does anyone know what it is with certainty? Perhaps a 70 series unit?
Obviously I realize one can be made but, I'm looking for a simpler solution here.
Bump
I’d look at 79+ that came with the large pattern knuckles. Can’t tell you for sure… I’ve got small pattern’76 knuckles with stock TREs.
It’s a 70 series, Cruiser Outfitters should stock them. I pieced together the TRE without the spot for the steering stabilizer for my LM7 build. Messed around on Rock auto and got the correct size taper and thread from 60 and 80 parts.
