What is this hose called? Power steering leak LX470
CloudCity
LuxCruisers
Palm Springs, CA
I’m fairly sure this is the cause of a leak in my PS system, a few drips per minute. What is this hose called? It seems like the leak isn’t originating at the pump but a few inches further where the metal line is fitted to the rubber section.
Replace the whole line if so, nothing I can tighten up right?
First pic is from the top with radiator to the right side.
Second pic is from below looking towards passenger side tire (US vehicle).
That appears to be the high pressure power steering line (44410-60593). You may want to cross-check you VIN on www.partsouq.com and doublecheck.
Yes, high pressure P/S hose. I'm a die-hard OE parts guy but this is one I would take aftermarket into consideration due the cost difference. If you have a local custom hose shop nearby (i.e. Parker), you might even be able to bring it to them and say "fix it" or make me one.
