What is the largest tire I can fit with no lift? (1 Viewer)
My take on 285/70-18 after doing the table above:
for street and dirt road it'll most likely work when doing the pinch weld mod, for more serious offroad it might rub.
<10% of the people seems to for bigger than 33.5" and yours would be at 33.7. So I personally would expect rubbing under full compression and turning.
FWIW, it’s more likely to run into issues based on width rather than height. Obviously you have to take both i to account but, the width hitting the UCA is usually the first BIG issue. Rubbin’s Racin’
My buddy runs 285/70/18's on his LX, stock offset with no spacers. He clears frame and UCA. He did trim the plastic around the pinch welds.
wanting to revive this thread... hoping someone has run/attempted to run 285/70/R18's on their rigs? Currently running these on my 200
Definitely pushing it if you're not doing any work to make them fit.
I had 295 70 R18 and it absolutely needed the pinch weld flattened, and 1" spacers. And it still hit the washer bottle
1.25" is the most popular spacer size so that's usually what gets used. I've read here that you need at least 1" if you want to use the flat caps. I don't know of anyone using 3/4" on RW's.
I use 3/4" on RWs, from what I remember all that's needed is about 1/4" - 3/8" to clear the center caps.
I have used 1/4” and 3/8” on RW’s, neither are enough for the flat cap to clear.
  • Like
Reactions: GTV
I think you’re missing the point here.
Flat center caps do not fit with 1/4” or 3/8” spacer. Dome center caps do.
Ah, we're talking about two different things (axle dust caps vs wheel covers), my bad.
Thinking 275/70/18 KO2s on my 2005 LX470.
1. I hope there will be no rubbing in the “normal” ACH height? Correct?
2. What about “low” ACH position? Rub no rub?
3. Should I go with 275/70/18 or 285? If 285, what aspect ratio?
Thanks!
Purely FYI, forgot to comment earlier:
285/75-16 Mickey Thompson Baja Boss A/T have VERY slightly hit my windshield water reservior under full compression in an offroad park. Pinch weld is stock and not modded, no issue there.
Nothing to be concerned, just to let you know.
Thanks!
I have no issue with 275/70/18 at all on my 2004 LX470.
Just got my 1998 Land Cruiser and needed new wheels and tires. Came with 305/50/20. Wanted to go to a 17" wheel so I bought a set of Method 309 Grid 17x8.5 0/4.75" Offset spacing. Was wanting to put 275/70/17 KO3s on them. Just want to make sure that they will go on without any mods or rubbing. Seems like from reading and searching through the forums that they should work, but I want to be sure. New to this game and trying to figure out offset and such. There is no lift currently on my rig. I look forward to the replies. Thank you.
275/70R17 would be about an inch taller than stock, and wouldn’t normally be an issue, BUT your proposed wheel is 0.5” wider, and 0 offset, which I believe would push the wheels outward 2.61” (0.25 + 2.36). If it were mine I’d be looking for something closer to the factory offset of 60mm.
Ended up going with 265/70 17 on the Methods. Have a slight rub on the front wheels at the pinch weld plastics area. I'll either cut or remold the plastic, do the pinch weld mod or raise the front end slightly with the torsion bars. Now to chase down the vibration that has been there since I bought it a couple weeks ago.
You can easily resolve the plastic fenderliner interference with a heat gun and maybe 5 minutes of your time. Very simple to just heat it up slightly and press it inward maybe 1/2" until it cools back down. That's what I did...
-G
I cut the piece away which was not a good idea as it‘s exposing the seam. Better to do the heat gun method.
  • OkYa
