What have you done to your 200 Series this week? (28 Viewers)
I think the new owner recently posted it on FB as well. There is a thread with some pictures from the build.
Thread 'Locked, geared, lifted, and fully built LX 570...on 37s - Denver'
SOLD - Locked, geared, lifted, and fully built LX 570...on 37s - Denver - https://forum.ih8mud.com/threads/locked-geared-lifted-and-fully-built-lx-570-on-37s-denver.1174209/
Yeah, the pre-16 LX works with a lot of other options. I'm not sure how well a 16+ would fit
Broke windshield #2. Rock flipped up from a semi about 20 mi south of Boise. By the time I got to son’s house in SLC, it had spread to about 5” and no longer repairable. Aarrgghh
Happy with how it turned out? Hail Repair, correct?
Yes, hail repair. It turned out really nicely. Sadly the hail, while extensive, didn't hit every single panel. The front/rear doors, rear bumper and rear hatch didn't get repainted. So now the little flaws in them are grabbing my eye and making my OCD fire off. Sigh.
It is nice to have the Rhino bumper painted and I also had the earlier 200 black window trim and 3rd quarter windows installed. I can't believe the difference that black trim makes! I put my FJ40 "Heritage Edition" badges on today, tomorrow morning I'm wiring the winch and winding the rope on it. Then it should be pretty well set.
New battery this week from Costco after the truck was getting more and more reluctant to start on the factory Panasonic.
First oil change since installing the jowett valves. Makes it a breeze and super clean. Not one drop on the driveway and I didn't even bother to put a mat down. Stuck with Pennzoil Ultra Platinum 5w30. I'll be sending a sample to Blackstone to compare to the 0w20 results I sent previously. 6,000 miles on both samples. Will post the comparison when received.
Ready for the 2000 mile road trip for in-law Christmas.
any links to the valves?
I would have paid the difference to have the rest of the panels painted at that point. Hope it doesn't drive you too crazy
I’ve replaced enough panels over the years that I’m to the point of traveling with a windshield repair kit to be used within minutes of a rock strike.
They appear to be sold out. Maybe @bjowett has another batch coming soon?
The difference would've been thousands and thousands of dollars.
Finally got my winch all set up. Hooked up power and ground and wound the rope on. Going out now to tension the rope with my friend.
I replaced the navigation touchscreen on my 2010 LX today. It was yellow when I purchased the car. I used that fact to get more dollars knocked off the purchase price, and managed to fix it for less. I'll take it!
There wasn't a very good resource specific to doing this on the LX 570. I cross referenced multiple videos from multiple Lexus models, and also leveraged the brain of @nwfl4runner, who has done the same procedure on his LX.
I purchased the Toshiba LTA080B922F panel from AliExpress. Here is a link, and here is a picture for when that link dies.
Not gonna lie - this job stressed me out. I'm a 1.5 :banana: mechanic - the most advanced thing I've done is AHC globes/fluid and changing spark plugs. I've never touched a ribbon cable before, and every connector has a slightly different mechanism to release the cable. I almost quit 5 minutes in.
I'll do a full write up and post a full video in the future. For now, here are some pictures.
I don't know how @NKP Garage does this stuff one handed, much less without a lot of edits. I think I shot 2 hours of footage, which is mostly of me cussing.
Success! The screen doesn't have that dark spot in the middle - it just looks that way in this shot.
Put on my FJ40 "Heritage Edition" D pillar badges and tensioned the rope on the winch
No eta at the moment, I will update when that changes.
Picked up a rock chip in my windshield today. Awesome, first day driving it in 3.5 months. Hopefully can get it fixed after the holidays and before it cracks
Any insight on which brand kits are good? I have a chip that needs some TLC and there are a zillion different kits for sale.
Serpentine/Tensioner/Idler Pulley - Water Pump looks good too!
Took about 2 hours and went from the bottom. Tensioner release bolt is 14mm and is a left thread to allow for you to leverage on it, needed to use a pipe extension.
Torques below for reassembly:
Tensioner - 6mm Allen is 17 ft/lbs
Tensioner - 12mm Socket is 17 ft/lbs
Idler Pulley - 14mm is 32 ft/lbs
Attached in photo's is the belt route diagram to snake the new belt through. I started idler pulley side from the top and worked my way down then back up again and across to the passenger side. Once the belt is routed I leveraged the tensioner again and got the belt over. Did a once over on each pulley to recheck they had been seated and proceeded to adjust them until they fit.
The foreman Mille Mayhem was overseeing QC
I have used the permatex kit multiple times with good results, though it can be figity. Don’t press the syringe into the base too aggressively or it may crack, and injecting the resin into the base can be messy if you don’t insert the tiny bottle in and sort of pump the fluid out in little spurts.
But if you can catch the crack before it is too big to go under the round adhesive it works well enough.
Saturday afternoon project. Added an Orangeboxx fold down table to the LFD hitch mounted swing arm. Very well made and fit perfectly on the arm. Clears the tail gate while down and tucks in nicely while closed. Looking forward to doing some cooking on this.
