What have you done to your 200 Series this week? (29 Viewers)
Aliexpress side pocket and amazon shifter. It’s the little things
Funny, mine just arrived today😁 Now I'm trying to figure out how to fit a bigger cup holder in the front when it's so close to the center console.
New stock battery terminals. Mine weren’t absolutely horrible, but enough of the coating (lead? tin?) had been removed that corrosion could happen.
Negative 90982-06059
Positive 82675-60020
Sir, your OCD puts my OCD to shame - kudos 🤪
Your contributions to the forum are always very much appreciated - thank you!
Thank you!
Tbh what prompted this one was getting really light corrosion around the base of one, despite having a healthy battery and charging system. When I investigated I noticed bare copper, so I pulled these off the shelf and tossed them in.
If I’m ocd about anything it’s corrosion..
looks great
is that shifter from sienna?
i am waiting to do my steering wheel like yours
Thanks! It’s the 2016-2020 shifter knob. Silver- Gray color matches perfectly to the same colored trim around the dash and console.
It does sit a little lower than the old one, but not enough anyone would notice. I only notice because it “feels different” vs the original type
Toyota pn 33504-60450-C0​
I switched my 2010 LX570 wheels to the stock 18" wheels someone was selling from a 2021 Land Cruiser ($325 for all 5, including the tires). I don't really notice a difference yet. But it's probably because I am a noob...
Before:
After:
Nice! Now for some meatier tires to fill up the wheel wells...
275/70R18 (33.2") for reference.
There was a smidge of rubbing inboard side of front mudflap at full lock, which was remedied by heat gun and a 2x4 reshaping it.
I would like to have a wider width tire, say 285 or 295, but did not want or need LT rated, so I decided to stick with SL rated.
But these fill the wheel wells nicely.
thanks!
my wheel and buttons came today
Looks great! No rubbing with the 70? And do you miss the width of the 285 VS 275?
You're never gonna notice the difference driving with 275 vs 285
Finally got around to installing some accessories that have been sitting in the garage.
Upgraded my National Luna 60L Dual Zone fridge control panel for the new Bluetooth panel. Allows me to control the fridge temps remotely. While driving, can bump down the temps on each zone. Then raise temps back to normal setting when at camp to reduce load on battery.
5-10 min upgrade.
Installed Kaon rear seat delete mounting points. Got tired of looking at the holes and I really like Kaon.
Upgraded my Front Runner Wolf Pack Pro mounts on roof rack.
Replaced these:
with new version:
The original mounts were ok, but I didn't trust them alone and added Rollercam tie downs for added safety.
There have been reviews of the Wolf Pack Pro's where people have had water leak inside between the lid & container on the sides. The upgraded mounts cover the sides while applying additional pressure when mounts are latched shut....
IMHO - most Front Runner gear is overpriced and overhyped. In this case, I'm paying for convenience. These mounts are solid and takes seconds to mount or remove the Wolf Pack Pros on the roof rack.
Finally wired the daytime running light option of my Baja Designs LP6's. I like running the OEM DRL's on trails (and in traffic) for safety reasons but have had friends complain of the brightness when spotting me. Figured the low amber DRL's on BD's is less intense and I have not found anything new to occupy the last free slot on my SwitchPros in the past 2+ years. FWIW - you can configure the switch to remember last setting when on, so not constantly having to turn back on with the panel when starting truck back up after breaks and then turn off when back to suburbia.
What front license plate holder is that? I've got that same front bumper, I like how you painted it, I was just going to paint the side "wings" of mine but now I might do what you did....
Thanks. It's the Rhino Swing Away Number plate bracket. Yours should have come with one?
Oh! I didn’t know this was an option. I’m now on the list to be notified when in stock for my 2015 90 Twin.
