What have you done to your 200 Series this week? (18 Viewers)
3 quarts total. I set vehicle to low and pumped the reservoir then bled all 4 corners. Removed 3 quarts and replaced 3 quarts.
Something got hung up/snagged on our bumper...
:D:cool::clap:
What did you use to get the old fluid out of the reservoir and put fresh in? Some small OD oil transfer pump?
Quick, use it so you can't take it back. Very nice rig, COMFORT in caps. Congrats.
It followed us home, we have to keep it:)
Thanks!
Not mine but I drive it:)
New 285/70-17 BFG KO2
Maltec 200 is without question the fastest, best handling, and smoothest riding expedition camper available. Making it 100% wife approved.:D
That’s interesting it doesn’t have sliders. Are they available? Also is that the VPR front bumper? I’d go with a traditional ARB/TJM if it was me - I’m guessing Maltec offers those an option?
Pretty sure I recall Alex saying the one we saw in Telluride had a Maltec-designed-and-built aluminum bumper.
They dont see a lot of rocks, sand is what they deal with the most. Bumper is aluminum and built by Maltec. As for options because most builds are custom everything is available.
Is that a Load C KO2? 285 75 17 / E would have been too much for it? Is that a 2.5" lift?
I'm on the fence between those two sizes with a 2.5" OME.
Went with tire rated at ~2750 lbs per tire. The 200 weight is ~7000# our tire guy thought the E rating was too much given the off road use and vehicle weight.
No lift the European Land Cruiser are available with AHC. :)
My bet is they are the Load Range E version:
  • MILEAGE WARRANTY
    STANDARD
  • SIDEWALL
    RWL
  • RIM WIDTH RANGE (MIN/MAX)
    7.5" - 9"
  • SECTION WIDTH ON MEASURING RIM WIDTH
    11.5" ON 8.5"
  • OVERALL DIAMETER
    32.8
  • REVS/MI
    635
  • TREAD DEPTH (IN 32NDS)
    15.0
  • MAX LOAD, SINGLE (LB @ PSI)
    3195@80
  • TIRE WEIGHT
    58.11
Personally, I find it gratifying that they chose to use the tire size recommended by Toyota for the LC200 ;)
And yet ... Toyota recommends the LT285/70R17 Load Range E tire for the stock LC200 :hmm:
