What have you done to your 100 Series this week? (100 Viewers)
My partsguy/fellow Cruiserhead recommended 200 series wipers when I went to order refills from him. Said they're better and the refills are cheaper. They're def. longer than the 100 stock ones.
Sounds like we have the same parts guy.
Got mine installed earlier this year with new glass and everything's "marvelous." LOL.
Installed some BenCC fog light inserts with Diode dynamics sports, highly recommend. Ordered these a year ago and the wrong ones were sent out. He sent out the correct ones asap. Wish I needed more stuff from him cause I would 100% buy from him over and over.
I did not! were those supposed to go inside the frame rail?? I was under the impression they went between the bumper and the frame. I wasn't a big fan of the directions, I would have preferred a video.
The spacers or shims go between the frame rail and the Dissent frame bracket. Its used to level and control the gap.
I was at Sturgis this year with my 01’ LX470. Complete loss of brakes with that darn buzzer.
The line break was at the coil of brake tubing, under the booster to the frame brake run.
I didn’t have another 3 weeks to wait for the OEM.
I ended up buying 3/16x24” steel line with the correct treads at the O’Reillys parts store in Sturgis, South Dakota. Used my tow receiver ball and their various circular shapes for bending by hand.
3 cans of dot3, 10mm flare wrench and bleeding, made it home.
Replaced a broken side marker light. Now I’m going to have to do something about the aging of the reflective coatings of the headlights too. You never realize how much luster has been lost until you see what new use to look like. I only broke one, but decided to replace both sides while I was doing it.
Replaced a broken side marker light. Now I’m going to have to do something about the aging of the reflective coatings of the headlights too. You never realize how much luster has been lost until you see what new use to look like. I only broke one, but decided to replace both sides while I was doing it. View attachment 3975742View attachment 3975743
Hey, got the part number for those? (I know, I'm lazy and don't want to look it up. I replaced the main headlights a couple months ago.)
LENS & BODY, FR TURN
Part No.: 81511-60500
Part No.: 81521-60370
Got them from toyotapartsdeal.com for $64 each. Not too bad.
When you ordered the headlights were they the glass lenses ones? I can’t seem to find that description in the listings yet and don’t want to swap mine for plastic ones if I don’t have to.
Yes, they're glass. I thought they were all plastic now, but for my '99 they're glass. Thanks!
I think it is fairly impressive to be that low for a 21 year old car :-)
Decided to check my wheel bearings as part of chasing a “wah wah wah” I get from 45-55 mph. I repacked then 25k miles ago, and the Timken bearings only have 85k since new. No play at all. The nuts were hand tight. Right side black grease around the bearings. Driver side I was greeted with dark black grease on outer, and red on inner. Outer bearing was shot. I couldn’t get a good bearing today, the best was a Napa Chinese one. I’ll change it out next repack. I’m baffled how that bearing wore out so fast. I’m pretty anal about following the book on this job.
